This may turn into a long post....
First of all, my car is a 92 Nz new SW20 Mr2 (3s-ge) and im taking it on Chelles' Trackday on Queensbirthday weekend around Taupo. The car has just under 185 ks and is due for an oil change, air filter change and the thermostat needs replacing as well.....so it will be booked in for those in the next couple of days
Im tossing up whether to
a) Just do the oil, air filter and thermostat as i *may* be selling it soon after the Trackday
or
b)Get the cambelt, seals etc done when i go for this next oil change as well as replacing the platinum spark plugs, looking at the water pump etc so that it will be nice and fresh for the track day....if that stuff is going to break, it will be on the track for sure.
The problem is....the cambelt isnt due for another 15 000 kms and I may sell it so i dont want to spend 800 pesos if im going to sell it....If i was defineately keeping it id just get it all done...
Second question: When accelerating, i can feel small transitions at certain revs...not really hesitation but it feels like it hits a spot and gets a bit more power...is that just the variable intake length switching over??
Third question: Any ideas for some simple things to do/check before taking the car on the track (apart from the obvious coolant, brake fluid, oil, tyre pressures etc)....
Opinions on whether to keep the spare tire in or out? Mr2s are slightly vauge in the front end anyway so taking out that weight may do more harm than good??
Cheers for any opinions...
