light weight wheels
light weight wheels
Postby barryogen » Thu Apr 20, 2006 2:52 pm
I've tried search here, and I've tried google, but nothing I can find gives me the details I need.
I'm trying to find out what a normal mag weighs, I understand that 12-19lb is considered light weight but what does a typical 18" wheel weigh?
mines 12.7lb according to the net, I take it that this is a good thing?
barryogen
2ZZ Guru in training
Postby Stealer Of Souls » Thu Apr 20, 2006 6:12 pm
http://www.geocities.com/srsvengence/ts_tech/mags.pdf
It's a little old. The source I stole it from has a new version which I haven't yet pillaged....
'86 AE85.5 Levin
Stealer Of Souls
Postby Emperor » Thu Apr 20, 2006 6:23 pm
http://www.active-x.net/cgi-bin/~initia ... 1140254833
I uploaded a bunch on there, your wheels might be under there, Aftermarket I assume?
Emperor
Postby barryogen » Fri Apr 21, 2006 10:01 am
Emperor wrote:http://www.active-x.net/cgi-bin/~initialdx/yabb/YaBB.cgi?board=carz;action=display;num=1140254833
Thank you, much abliged... mine are one of these, will have to actually look at them though to be sure.
Wed's TC-005 SSF 16x7 5.8
Wed's TC-005 SSF 16x7.5 6.0
Wed's TC-005 SSF 16x8 6.3
The ones I was looking at are these ones I think...
ROH Adrenaline Cast 18x7 11.6kg
I'm not so keen to add ~6kg per wheel to my car.
barryogen
Postby Stu- » Fri Apr 21, 2006 10:15 am
My Wed's (15") are 3.5kg each. Quite a bit better than 17inch EVO R's which weigh a ton.
Project Thread
Stu-
