Caldina sparks
Caldina sparks
Postby GT4 20 » Thu Apr 20, 2006 7:33 pm
Am correct in assuming that the Caldina GT-T uses coil packs rather than a dizzy? If so, where is the crank position sensor? Does it read off the flywheel?
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby fivebob » Thu Apr 20, 2006 8:07 pm
Yes, it's on the crank behind the timing belt. Sensor is at the bottom. There's also a single tooth cam position sensor which is needed so that it can have sequential ignition instead of wasted spark.
Postby GT4 20 » Thu Apr 20, 2006 9:10 pm
Cheers :D
Gary
GT4 20
