FWD toyota springs... what fits what?
Postby KinLoud » Fri Apr 21, 2006 8:59 pm
Just doing a bit of homework for improving my 20v Marino's handling.
About to replace shocks and springs.
I would like to know if diesel corolla springs have a higher spring rate? If anyone has access to a diesel corolla and a set of calipers... please measure the spring thickness (should be between 12 and 15mm).
Also - has anyone found springs from different toyotas that fit onto the AE101 corolla front or rear struts?
Thanks
Ken
Ham
021 408 863
Postby Mr Revhead » Fri Apr 21, 2006 11:43 pm
santa (think it was him, may have been snwtoy?) noted that the king springs in his gt-t caldina were the same part number as king listed for i think ae101....
Postby NA Drifter » Sat Apr 22, 2006 7:12 pm
probably good to get some spring reference from
http://www.kingsprings.com/
maybe some of the parts numbers are the same with other Toyota, hence they use the same springs....?
Keith
NA Drifter
Postby Mr Revhead » Sat Apr 22, 2006 11:28 pm
same shape, not the same rates.... thats one of the problems with king springs
Postby KinLoud » Sun Apr 23, 2006 7:55 am
Thanks guys - not looking to lower the car much if at all, just want it a bit firmer in the ride department.
All donations of unwanted toyota springs will be most welcome.
Ken
Hamilton
021 408 863
Postby Santa'sBoostinSleigh » Mon Apr 24, 2006 10:04 am
King springs that were in my GT-T were the same physical size as my AE111 Dobi Sport and my GT-T Teins
note that coil spacing and number of coils were different
also note that the Kings in the GT-T were not designed for a caldina, they were listed as fitting AE92/100/101/111 and some others
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Silent Knight » Mon Apr 24, 2006 10:06 am
Yea Jason has a set of King springs in his Caldina that was listed for an AE chassis and they were shit.
They were soft and bouncy and in the space of I think it would have been 6 months the sagged down that much that he could not get a warrant anymore.
Stay away from them. Go for some Tein springs. Good quality at a good price. Hopefully they make something that can fit a Marino?
Silent Knight
Postby Santa'sBoostinSleigh » Mon Apr 24, 2006 11:39 am
thats why i put the Teins in mine, so much better now
was a rough bouncy piece of poo on the kings,
plus made it sit too low (for practicality, however it looked mint)
*edited for clarity*
Last edited by Santa'sBoostinSleigh on Wed Apr 26, 2006 10:48 pm, edited 1 time in total.
Santa's Mega Sale
Postby the fallen303 » Tue Apr 25, 2006 10:23 pm
Santa'sBoostinSleigh wrote:thats why i put the Teins in mine
after you put the teins in, or with the kings? if with the teins was it just a bit annoying for a daily driver, but good handling, or was it just really bad?
true house of JZ
Stay true to the origin
the fallen303
Postby Santa'sBoostinSleigh » Wed Apr 26, 2006 10:47 pm
kings = shitehouzen :(
tein = teh sex
;) comprehende?
Santa's Mega Sale
Postby the fallen303 » Wed Apr 26, 2006 11:45 pm
8) :twisted:
true house of JZ
the fallen303
Postby DRFTIN » Thu Apr 27, 2006 12:06 am
[quote="Silent Knight"]Yea Jason has a set of King springs in his Caldina that was listed for an AE chassis and they were sh*t.
quote]
how much heavier is a caldina than a corolla? of course the light little corolla spring will make it handle bad
so a caldina spring should be a good upgrade for the marino?
DRFTIN
Postby KinLoud » Wed May 03, 2006 10:13 pm
Spent yesterday afternoon at Pick a part otahu playing mix and match.
- Diesel corolla front springs seem to be the same as 4afe corolla springs.
- Rear ST182 springs fit pretty well into corolla rear struts - the spring wire is thicker but the coil diameter is bigger so the spring rate is about 15 to 20% higher.
- Front ST182 springs won't fit into front corolla struts as the bottom coil diameter is about 10mm too big.
I see on the King spring website that ST162 springs are the same part number as corolla springs - I will have to find a set of front springs to see if they will fit into corolla struts.
Anyone got a set spare?
Ken
Ham
021 408 863
Postby neo » Thu May 04, 2006 2:53 pm
Good hunting so far Ken,
When you find a approx std height + firmer spring for the front and back tell me, this will be a cheap compromise gravel + track setup..
Chur
neo
