i have failed my wof because of a suspected leaking brake master cylinder...
the guy said if it wasnt leaking to dry it up and take it back clean.
if it is leaking what is involved with replacing/fixing this?
Rick wrote:Its just a matter of replacing th seals, but if the cylinder is corroded then you might have get a new master cylinder, or a non corrroded second hand one.
Nuty|Mike wrote:Rick wrote:Its just a matter of replacing th seals, but if the cylinder is corroded then you might have get a new master cylinder, or a non corrroded second hand one.
Ill have a look for a new cylinder at work for you no point in changing seals when a whole new unit aint gonna be much more expensive
gepsk8 wrote:if the cars got a EFI 4age which im guessing it is, it will take a bit of time to get at, as i wrecked one and it still looked like a mission to get at if the motor etc was in the car.
