st205 3sgte engine into st206 curren?
Postby Infinite » Mon Apr 24, 2006 11:06 am
ok i have a st205 3sgte engine havent payed for it yet, now would this be easyly fited? i was told to go for a corrola/caldina but havent been able to find one... so would this fit?
Lots
Infinite
Postby RomanV » Mon Apr 24, 2006 12:16 pm
Yes it fits. 8)
Just need to use a modifed SW20 gearbox, as you obviously cant make the curren 4WD. (well, unless you have access to Scrooge McDuck's vault)
Celica and currens are virtually identical, well the NA ones anyway.
As for easily....
That depends.
IF you have a million dollars, and want to pay someone to do it, then yes. it is very easy.
If you want to do it yourself, and have no idea what you're doing, then it's very hard.
However it is definitely feasable.
Postby cr1mnl » Mon Apr 24, 2006 7:06 pm
you can use factory gearbox as i have in mine but would recommend upgrading to a mr2 box like i probably will when funds allow
www.ology.co.nz
cr1mnl
Postby Infinite » Tue Apr 25, 2006 9:18 am
runing a st202 5spd lsd :)
Lots
Infinite
