engine transplant.
engine transplant.
Postby Infinite » Thu Apr 27, 2006 6:44 pm
ok,
what is the best way to remove a 3sfe auto box drive shafts ect ect, then im going to be puting in a 3sgte new box and drive shafts... problem is havent got the ability to lift it right up into the air!. but do have a couple of block and tackel's. Also i havent ever pulled a fwd engine out befor so if u could inform me of knucle skinning areas lol and any other good stuff :)
thanks
Lots
Infinite
Postby Ae92typeX » Thu Apr 27, 2006 7:11 pm
take bonnett off. unplug/remove wires etc, drain fluids. Remove radiator. Undo/unplug shafts- which can mean undoing lower ball joints to ease pulling out.support engine with tackle and remove mounts, pull out.
If you can do on a rwd, can do on a fwd.
unless, when you say you dont have the ability to lift in the air, you also mean you cant lift the engine...then theres a problem.
Ae92typeX
Postby Infinite » Thu Apr 27, 2006 7:20 pm
ok, narh was told to remove along wid subframe then lift the car up but cant do that but can hall everything out the top!
Lots
Infinite
Postby Grrrrrrr! » Thu Apr 27, 2006 9:31 pm
You may find its a lot easier to drop the subframe... thats how they install them in the factory, and thats my prefered way of getting FWD motors out, having tried both ways. the block and tackle will easily lift the front end of the car off the ground far enough to slide the motor and box etc out. just need to find a nice long strap to wrap around something solid while you do it.
just make sure you have disconnected ALL the electrical bits first, dont forget the oxy sensor and the cat temp sensor if you have those!
Grrrrrrr!
Postby cr1mnl » Thu Apr 27, 2006 10:24 pm
i take out and put in my engine from under the car too. just jack car up, block wheels, block up jack, jack up car etc until high enough to slide motor out underneath.
www.ology.co.nz
cr1mnl
Postby Ae92typeX » Thu Apr 27, 2006 10:30 pm
yeah, I do both ways also, but quite honestly dont find either particularly difficult or more time consuming than one another.
Ae92typeX
