My car is 1998 AE111 Levin BZR
The problem is with the fan and aircon controls.
1. When I drive, sometimes it suddenly changes temperature to hot, This happens not just with aircon on, but with aircon off. Even when the fan is off, u can still feel the hot air coming out
2. When I change the temperature to hot, then back to cold, it will work fine, but after a few minutes it switches itself back to hot.
3. Sometimes when I choose Cold, or Hot. i.e. 18 for cold, or 32 for hot. Both selection blows hot air out. BUT if i choose 25, it blows cold air.
4. I have took the control off and checked and it is actually not controlled by wire, it is all electronicly controled
5. I have checked the air temp sensor underneath the steering wheel, and it seems to be fine and all connected
6. Checked all fuse
7. Checked the actual temperature control under the bonnet. (at first I thought it was that, but when i did further tests, it seems to be the Controls fault)
The question now is, What else I shd check, or is it 100% the control's fault that its buggered? If so, Anyone know where or who in auckland or else where wrecking a BZR? I have checked pre-facelift BZG, but they are controlled by wire, so no use. I need something from a facelift BZR or BZG.
Below is a pic of the controls from the Levin Manual
