Blow or Suck?
Blow or Suck?
Postby Go_the_mini » Fri Apr 28, 2006 3:12 pm
Hay just wondering whats going to give me the best effect on my 4k? blow threw or suck threw?
Go_the_mini
Postby evil_si » Fri Apr 28, 2006 6:22 pm
do u intend to intercool?
if so, go blow thru,
evil_si
Postby cr1mnl » Fri Apr 28, 2006 7:19 pm
depends on your budget. suck thru is cheap and nasty. only advatage is cost as you dont have to use a modified carb but as si says you can't run an intercooler or bov. blow thru is by far a better option if you can afford it.
www.ology.co.nz
cr1mnl
Postby slighty_sykotic » Wed May 03, 2006 12:54 am
Out of interest, how/what do you have to do to modify the carb for blew through?
--Sykotic
slighty_sykotic
Postby cr1mnl » Sat May 06, 2006 12:03 am
carb need to be fully sealed, fuel bowl needs to be pressurised, float needs to be solid so it won't collapse and jets modified to suit the boost level.
www.ology.co.nz
cr1mnl
