shifter cables
shifter cables
Postby bluemaumau » Mon May 01, 2006 6:39 pm
ok when i pulled the 4afe out i ripped the rubber coat ( is it called a gaiter) of the gbox end of the cable.
question is:
how do i replace this part as i cant see a way of removing it, im guessing ill have to buy a whole new cable
or
do i need to use the gtz ones ?
Postby bluemaumau » Tue May 02, 2006 7:27 pm
bump
Postby ZE WAGON » Sat May 06, 2006 8:47 pm
not sure if you can replace the rubber cover...but the 4afe shifter cables will hook staight up i should think. I had a 5afe in my wagon before i converted to a ze and the standard shifter cables work a treat.
home is where you make it!
ZE WAGON
Postby bluemaumau » Sun May 07, 2006 1:20 am
yea i might see if the gtz cables fit cuz ill need to replace the one i fukd
