Who supplies tein suspension
Postby trd-drifting » Tue May 02, 2006 10:01 pm
ok is there any any one in nz that supplies tein suspension in hamilton as i am after 3 top hats (I think that what they called.. I no next to nothing about coilovers) for some tein adjustable coilovers. Or can i use the factory ones in my mkiii (supra) i doubt it because springs sizes will be different.
Any help or getting pointed in the right direction will be awesome... Thanks
trd-drifting
Postby THA SHZ » Tue May 02, 2006 10:37 pm
Autolign , the shock shop .
If you have one of these there than thts your place to go , otherwise failing tht let me know and i may be able to sort it for you 8)
THA SHZ
Postby YeMs » Tue May 02, 2006 10:43 pm
i installed a set of tein adjustables on the weekend into a cefiro. what exactly are you after? i used the standard top hats.
Your local Hybrid Elite tech
YeMs
Postby trd-drifting » Wed May 03, 2006 8:00 am
Um well i just have the shocks and springs and they are adjustable. Um i thought you would need new like top hats so they would be captive casue i thought the springs would be differnet, they are specific to my car so are you saying i dont... Any tools i need besides your standard tools. Also to change ride hight when in the car is that possiable and how... Just trying to sort evrything out before weeknd as i want to put in hehe
trd-drifting
Postby TWSTD » Fri May 05, 2006 12:31 pm
Im not sure if I understand correctly, but you have a set of Teins with no top springseat or tophat? In general you should be able to use the factory top hats, but you will need the Tein (or other sim) spring seat as the coils are likely to be 60mm coils which are most likely smaller than your factory coils - so the tein springs will not locate correctly with your stock spring seats.
Click here!
TWSTD
Postby 3T-Rona » Mon May 08, 2006 8:42 pm
yeh like said, u should have a spring seat. this sits ontop of the spring, then ur factory top hat sits ontop of that. no u cannot change the ride height inside the car, u adjust the ride height by threading the bottom cup up or down. there is only limited height adjustment.
3T-Rona
Postby XS1V » Thu May 11, 2006 9:56 am
We (Advanced Automotive) are one of the NZ distributers of TEIN o if you need new ones or advice give us a call (09)441-6988
ST205 Group A Rallye #2363
XS1V
