vvt on 20v silvertop
Postby l3_vin » Sat May 06, 2006 11:48 pm
when does it kick in?
l3_vin
Postby bluemaumau » Sun May 07, 2006 1:15 am
search
Postby l3_vin » Sun May 21, 2006 2:53 pm
ok i did
i found it kicks in at 4000 rpm and ends at round 7.
just to clarify....is this true?
l3_vin
Postby Punter » Sun May 21, 2006 5:59 pm
Sorry, but I won't answer until you put a sensible size picture in your sig. :P
Punter
Postby Mr Revhead » Sun May 21, 2006 6:12 pm
no its not true.
its load dependant
basicly once its half warm anything over 1/4 throttle and it kicks ins.
cant recall exactly the switch off point but i tthink its around 6800
Postby trueno_20v » Sun May 21, 2006 6:38 pm
on the silvertop ino it turns off at 7500
ADMIN EDIT: signature too large
trueno_20v
Postby Bazda » Sun May 21, 2006 7:30 pm
no its 7000.
http://www.billzilla.org/4agstock.htm
scroll down to the bottom it tells you everything about the cams.
Postby AceSniper » Sun May 21, 2006 8:40 pm
id agree with 7k, given the fact factory tach is out by around that much in them rpm's
AceSniper
