Boot spoiler removal - AE111
Postby redline racer » Sun May 07, 2006 4:43 pm
Hi i have a Ae111 levin, possibly looking at removing the boot spoiler.
I have seen there are two nuts to loosen from inside the boot lid, and the adhesive gunk on the outside, but i think i can also maybe see a clip? (through the gunk)
The spoiler is still very firm with the nuts loosened and the adhesive is fractured/weathered, so surley there is something im not doing here?
Any advice apperciated
Cheers.
Last edited by redline racer on Sun May 07, 2006 10:34 pm, edited 1 time in total.
redline racer
Postby Jazza » Sun May 07, 2006 5:36 pm
My curren spoiler has 5 bolts. 3 are easily visible. 2 are hidden and it took me ages to find em. Maybe thats an option? Check under your boot lining...
Jazza
Postby redline racer » Sun May 07, 2006 10:33 pm
cheers jazza il double check for hidden bolts, could only see two when i had a look, but like you said some could be hidden.
redline racer
Postby Bling » Mon May 08, 2006 11:50 am
iirc
1 bolt either side
1 plastic clip either side, about as big as 20c piece (ish) you'll just have to undo the bolts then slowly lever it till they pop out
Postby B1NZ » Mon May 08, 2006 6:02 pm
why why why why why??
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Brick » Mon May 08, 2006 6:42 pm
B1NZ wrote:why why why why why??
why not :)
Brick
I know Kung Fu
Postby Bling » Tue May 09, 2006 10:37 am
exactly, why? why not? personal preferences aye!
