runing car without intercooler?
Postby Infinite » Sun May 07, 2006 6:15 pm
Ok,
i have the 3sgte gen3 in the car but ive taken off most the top mount intercooler setup as i cant use it without a modifyed bonnet and also the guy who i got the engine off damaged the tank that sits behind it on the passengers side, so can i start the car and have id ideling without a intercooler setup?
Lots
Infinite
Postby slighty_sykotic » Sun May 07, 2006 6:22 pm
Are they map? if so, yeah you can, but will have no air filtering then, nor boost of corse.
--Sykotic
slighty_sykotic
Postby Infinite » Sun May 07, 2006 6:25 pm
narh i can hook up a pod filter to the intake so it will suck clean air there!
Lots
Infinite
Postby CozmoNz » Sun May 07, 2006 6:44 pm
Who needs an intercooler :D 7psi of mayhem... and det problems on hot days lol
Rayne For President!
CozmoNz
Postby DB4G63 » Sun May 07, 2006 6:50 pm
Who needs an intercooler Very<br />Happy 7psi of mayhem... and det problems on hot days lol
Look at that ugly engine bay! :D
And a lovely spacesaver too...Im surprised you have been showing off the new beast.
So whats the disadvantage of no intercooler? less power? more heat perhaps. More wear?
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby flygt4 » Sun May 07, 2006 6:54 pm
hahaha thats one of those leone wagons right?
me and a couple of mates took one for a testdrive once while looking for a paddock basher and it was a bundle of laughs. it was dripping oil onto the exhaust manifold and when we returned it after a quick drive there was smoke pissing out everywhere :D wasnt too bad for an 1800cc auto turbo but was still a heap of shit.
flygt4
Postby CozmoNz » Sun May 07, 2006 6:57 pm
Leone Coupe :P, Manual full time 4wd (hi low ratios / diff lock etc)
they are usually heaps of shit, unless you can find a decent one :D... (hence why i brought it)
CozmoNz
Re: runing car without intercooler?
Postby GT4 20 » Sun May 07, 2006 6:58 pm
Infinite wrote:Ok,
Do you mean the white plastic tank that bolts onto the strut bar?
As for running it, as above. Yes you can.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Infinite » Sun May 07, 2006 7:03 pm
car wont run, :( there is fuel at the filter up the front but i dont think its geting into the engine.... not sure if the fuel pump is turning on! will have to take it out of the tank tomorrow and try turning the car over see if its sucking...
Lots
Infinite
Postby GT4 20 » Sun May 07, 2006 10:02 pm
Why on earth would you wnat to do that when there is a far simpler test? Just disconnect the fuel line at the filter, have a suitable container at the ready (+ a fire extinguisher) and just turn the key. If the pump is working, the fuel will come out. Much easier than pulling the pump out at this stage.
If pump is working, then you know that there is a problem elsewhere.
Gary
GT4 20
Postby Infinite » Mon May 08, 2006 8:32 am
yea wanted to find what color wires were there aswell to make sure they went to right place at ecu trying to make a diagram for the curren....
Lots
Infinite
Postby sergei » Mon May 08, 2006 11:36 am
Usually it is Blue with White stripe (power for FP).. on the plug wich goes to fuel pump there should be 3-5 wires, one of them should be relatively fatter, and blue in color, this is the one to apply +12v, but only do that when Fuel pump test from diagonstics fail, to test fuel pump at diagnostics sort +B with FP, this should turn the fuel pump on when ignition is on. Or You could apply 12v staigh from battery to FP pin.
Postby Infinite » Mon May 08, 2006 1:02 pm
wired fuel pump to battery for test and car run fine :) will rewire the fuel pump into the 3sgte loom tonight
Lots
Infinite
Postby sergei » Mon May 08, 2006 2:56 pm
I'm not sure about gen3 but with gen1-2 there is fuel pump resistor, without that car will not run, it is usually located on the left front strut. It can be shorted with a piece of wire if you don't have it. This mod will make fuel pump go on "full" power all the time (like in most of the cars).
Postby Infinite » Mon May 08, 2006 7:38 pm
narh the fuel pump was to 3sfe spec wiring not 3sgte is fixed now! but i have a few extra wires to put in for the intercooler water pump :( nfi were they go yet lol other than that i think its basicly all done!
Lots
Infinite
Users browsing this forum: Bing [Bot] and 30 guests
