4age torque settings
Postby SpeedRacer » Mon May 08, 2006 9:56 pm
hey all,
re-building my 4age red top(bigport) and don't have a diagram or whatever with the torque settings.
I'm after Head bolts, rod bolts, exh/int, and cam gears (pretty sure cams is 43 ft/lbs)
Cheers,
-Speed
Sinister Sleeper 35
SpeedRacer
Postby slighty_sykotic » Mon May 08, 2006 10:04 pm
I can help you now im home :)
http://locost7.info/mirror/4age_blacktop.php
bt4-em.pdf 4211k 17 Jun 2002
Blacktop Engine Mechanical
8)
--Sykotic
slighty_sykotic
Postby sergei » Mon May 08, 2006 10:16 pm
4AGE 16v from Haynes manual:
Camshaft bearing cap bolts - 13Nm
Cambelt tensioner bolt - 37Nm
Camshaft Sprocket - 47Nm
Crankshaft pulley bolt - 137Nm
Cylinder head bolts - Step one - 29Nm
__________________Step two - 90 degree
__________________Step three - 90 degree
Exhaust manifold - 25Nm
Flywheel - 69 to 78Nm
Inlet manifold - 27Nm
Sump to block - 6Nm
Oil pump to block - 22Nm
Oil pickup - 11Nm
Rear oil seal retainer - 10Nm
Valve cover - 2Nm
Main bearing cap bolts - 60Nm
Con rod nuts - 49Nm
Postby SpeedRacer » Mon May 08, 2006 10:18 pm
Sinister Sleeper 35
SpeedRacer
Postby bbq1988 » Wed Dec 12, 2007 11:37 am
Sorry to dig up an old thread, but are these torque settings for all of the 16v 4A-GE's?
Baked, Not Fried.
bbq1988
Postby tsoob » Wed Dec 12, 2007 9:31 pm
someone please faq this
tsoob
Postby escortman » Wed Jul 30, 2008 8:46 pm
anyone know how much to torque up the oil squirters
4x4 toyota blizzard offroader
escortman
Postby crispy'86 » Thu Jul 31, 2008 12:30 pm
I'd be tigthening the oil squirters up 9-13Nm, admittedly i did mine with a 3/8" drive powerbar and socket but it will have similar result
crispy'86
Postby escortman » Thu Jul 31, 2008 10:39 pm
yeh thats wat i ended up doin haha
escortman
