hi i have an ae111 blacktop bzg 6 speed levin (1998)and recently i installed a wideband o2 sensor to get an idea of how my air fuel ratios are burning and i discovered im running rich
i get a 14.7-14.8 burn at idle which i believe is stoich but when i drive between 2 and 5k its 13.2, full throtle above 6k im at 12.6 and right b4 redline the wideband meter is saying 11.8
i have a greddy emanage installed and i would like to reduce the fuel from 6-8000 rpm full throttle to around 13.6
my questions
1. is 13.6 a safe a/r reading?
2. when i alter the airflow voltage at those parameeters will it advance my timing significantly? im thinking about a -40 on the airflow map on the greddy
3. what is the maximum timing advance on the ae111 4age blacktop?
4. shud i see an improvement in acceleration by slightly leaning out the mixture?
let me jus add what has been done to the car
short ram setup with an apexi power intake filter
imec throttle trumpets
jasma certified apexi exhaust manifold with 2.25" piping going into a apexi barrel tailpipe.(no cat 1 resonator)
toda flywheel
trd clutch and pressure plate
