Bleeding the clutch
Bleeding the clutch
Postby flat_0ut » Sat May 13, 2006 6:36 pm
Hey guys,
was planning to give my clutch a bleed. anyone know how to do it? a hard job? also how much fluid do you need for it. very approximate (ae92 levin 4age)
thanks
flat_0ut
Postby Ae92typeX » Sat May 13, 2006 11:44 pm
Easy as job.
Just buy a small bottle of fluid- it will be enough to flush the system fresh. Find some tube that will fit snugly over the bleed nipple. put on, with other end of tube in a container/jar. Loosen bleed nipple about half a turn, pump pedal. check fluid after every few pumps- you dont want it to go down far. Ideally, you will be able to see the container, and once all air bubbles and old fluid is flushed out, tighten bleed nipple, make sure fluid is topped up to max, and you are away.
Ae92typeX
