AE92 FXGT REDTOP SMALLPORT SPARK PLUGS?
Postby B1NZ » Mon May 15, 2006 6:10 pm
So apparently the factory reccommendation for spark plugs is NGK BKR6EP-8? Now what i want to know is can i get a set of copper ones> Do you just remove the "P" and it becomes a copper equivilent?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Dr.NoIdea » Tue May 16, 2006 11:08 pm
:( I have exactly the same question. went to the supercheap today and was told around 25 bucks for each plug, that's f***ing expensive.
Anyone knows the answer?
Bump
Dr.NoIdea
Postby Caveman » Wed May 17, 2006 12:44 am
IIRC BKR6EP-8 is 4AGZE platinum plugs. Expensive
Go to genuine toyota, they are like 3 dollars each and they will give you the right plug.
Caveman
Postby EVLGTZ » Wed May 17, 2006 3:48 pm
Change that P to an S for the cheapys
Work fine.
I used them on my turbo ZE (albeit a slightly different heat range)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby B1NZ » Wed May 17, 2006 6:16 pm
Thank you 8)
Subaru GF8 Wagon
B1NZ
