liquid nitrogen to air intercoolers...
Postby no_8wire » Mon May 15, 2006 8:01 pm
I know this may sound wierd...but with enough money could it be made to work? Similar to water to air...expect liquid nitrogen instead... only thing I can think of that would maybe stuff it up is
1: cost
2: extreme cold crack the intercooler steel/ makes it useless...
3: interesting valve system to be able to fill/top up...
4: cost
no_8wire
Postby RomanV » Mon May 15, 2006 8:46 pm
cold air doesnt atomise petrol as well.
So you get diminishing gains, not much point going much lower than ambient air temps IIRC.
And bearing in mind that if you dip a banana in Liquid nitrogen you can hammer in nails with it, I dont think that ANY piping is going to take too well to being that cold and having super hot gas running through it.
When heated, you'd probably get an explosive result when the liquid nitrogen turns back into a gas rather quickly.
Postby AE91Sprinter » Mon May 15, 2006 8:58 pm
Well, theres an easy way to try it. Make a box, pack the IC in ice and dyno run it. Or just do it for the hell of it and see what happens by feel if you dont have a dyno handy :lol:
AE91Sprinter
Postby no_8wire » Mon May 15, 2006 10:18 pm
explosive is not good... :lol:
no_8wire
Postby bluemaumau » Mon May 15, 2006 10:34 pm
very interesting idea. doubt it would be worth it tho for all the reasons mentioned.
Postby no_8wire » Mon May 15, 2006 10:40 pm
yeah was just an idea...not a whole lot of room in an aw11 engine bay...want the most effiecent cooling possible...
oh well might just stick to water to air...
no_8wire
Postby RomanV » Mon May 15, 2006 11:07 pm
Well it's not as if it would be a viable solution anyway...
Unless you like buying and handling liquid nitrogen all of the time. :)
Postby Stealer Of Souls » Tue May 16, 2006 9:35 am
Single shot wonder cooler?
Yeah. Re-liquifying the nitrogen could be a challenge?
Even sub-zero air can be use effectively if the engine is tuned to handle it. I've seen supposed results from a dry ice IC that had intake temps below zero. The before a suitable ECU tune had the engine lose power like crazy. But after a suitable ECU tune the engine cranked out some serious power. I don't know what fuel they had to use though... Maybe they went for something exotic...
'86 AE85.5 Levin
Stealer Of Souls
Postby Grrrrrrr! » Tue May 16, 2006 12:53 pm
It could be made to work.. might be a bit of a challenge tho.
Maybe a multi stage system to reduce the temperature difference between layers
Something like
Liquid N2 -> Alcohol(or other low freezing temp fluid) ->Water -> Air
a shot of Li N2 into a vented chamber in a brass or copper heatsink imersed in Alcohol, which is circulated thru a water to air intercooler as per normal. And when you run out of LiN2 at least you still would have a normal water to air type intercooler setup
Your litre or so of Liquid N2 would go a long way, but youd have to shoot it into the system a few seconds before you needed it to allow time for the thermal lag.
Also if the alcohol spilt onto a hot turbo manifold you could have a very nasty situation.. good old invisible flames with burning alcohol.
Grrrrrrr!
Postby Jazza » Tue May 16, 2006 2:38 pm
And the second you have a head on crash, your burning in 10000 pieces with whatever you hit.
Thats the main problem IMO.
1996 Curren - On Tardme
Jazza
Postby MrOizo » Tue May 16, 2006 4:16 pm
what about the CO2 IC systems?
http://cgi.ebay.com/ebaymotors/8-x-4-In ... enameZWDVW
'In action' - video http://www.diynetwork.com/cr/cda/player ... 35,00.html
would have to worry about exploding during impact if its securely in the boot. and would possibly aid in dampening the fire if one was to start 8)
MrOizo
Toyspeed Legend
Postby SpeedRacer » Tue May 16, 2006 6:12 pm
ive seen one with a box round the i/c and dry ice packed round it in a magazine once, duno if it helped or not but must of done something (bling maybe?)
Sinister Sleeper 35
SpeedRacer
Postby KinLoud » Tue May 16, 2006 8:17 pm
Use liquid oxygen... straight into the intake - no intercooler required.
You might however need a dangerous goods sticker "oxidiser" on you bumper.
Ken
GHam
021 408 863
Postby Grrrrrrr! » Tue May 16, 2006 9:07 pm
hmmm, and if add more than about 2% oxygen you'll be needing to up your fuelling very quickly.. oh and your exhaust valves will probably turn into nicely melted blobs in very quick order :)
Grrrrrrr!
Postby MrOizo » Wed May 17, 2006 9:14 am
SpeedRacer wrote:ive seen one with a box round the i/c and dry ice packed round it in a magazine once, duno if it helped or not but must of done something (bling maybe?)
wasnt a yellow GTi-R poohsar was it?
that is in this months Rev i think. was next to TS at the stand at the 06 Nats. the guy was always topping it up. looked pretty good and functional.
MrOizo
Toyspeed Legend
Postby Stealer Of Souls » Wed May 17, 2006 9:17 am
KinLoud wrote:Use liquid oxygen... straight into the intake - no intercooler required.
I've wondered about this. Like NOS?
'86 AE85.5 Levin
Stealer Of Souls
Postby SpeedRacer » Wed May 17, 2006 9:30 am
nah it was a white 5zigen WRX i think, was like 2 years ago in a nzpc mag
Sinister Sleeper 35
SpeedRacer
Postby RunningRich » Wed May 17, 2006 10:46 am
Jazza wrote:And the second you have a head on crash, your burning in 10000 pieces with whatever you hit.
Um, you do realise that nitrogen isn't combustible and does not support combustion, right?!
Richard
http://gtfour.supras.org.nz
RunningRich
Postby barryogen » Wed May 17, 2006 11:33 am
MrOizo wrote:what about the CO2 IC systems?
I could be wrong, but think he means more like this...
http://www.designengineering.com/products.asp?m=sc&cid=1
the aussie distributers are these guys.
scott@qri.biz Jason@qri.biz
the website is just some random free email thing though, so I'm not so keen to do business with them.
There was a guy with a WRX that was using a set of them to cool the air charge on PCTV either early on this season or late last year.
It's an interesting idea, basically this bulb thing sits in the middle of your piping, and cools the air that surrounds it.
install instructions(PDF) are here.
http://www.designengineering.com/images/installation_instructions/CryO2%20Tank%20install%20instructions.pdf
they should give better info on how it works.
barryogen
2ZZ Guru in training
Postby MrOizo » Wed May 17, 2006 12:29 pm
kinda wrong kinda right
its exactly what i posted :P
MrOizo
Toyspeed Legend
