KinLoud wrote:Is the rubber boot around the gearstick putting pressure on the gearstick that forces it out of gear...
Not the I could see at time of putting the box in there, but will have this re-checked just to be safe. (see comment below about quick shifter)
KinLoud wrote:I'm presuming that this is an engine/gearbox transplant job?
Yes & No, had to rebuild the blue top as it run a bearing on number 2, ended up replacing crank (slight crack), number 2 con-rod, all bottom end bearings new gaskets etc.
The replacement re-built T50 (20 spline) was brought in and swapped for the existing T50 (22 spline) which had major internal issues. At the same time a quick shift selector was added which has an additional base plate that raises it about 10 or so mm which I had to cut the trans tunnel to ensure clearance for the bolt in the bottom right hand corner (direction from sitting in drivers seat)
KinLoud wrote:I have had a similar problem with my racecar... difficult to get into 3rd gear sometimes - fixed now (I hope).
Ken
Ham
021 408 863
Was your issue due to pressure being applied by the boot on the gear stick? If so I assume that removing that pressure resolved it?
Blair
