what parts to build the ultimate 4agze
Postby soopachargen » Mon May 22, 2006 7:22 pm
I'm contemplating building a better gze using toyota parts. What would you consider to be the best combination of factory toyota parts to make up a tough street 4agze
    Must be 1.6litre
    must use a toyota block
    must use toyota pistons and rods
    must use a toyota head
    must use an sc14
    must use under $1500 worth of computer
    must run on 95 octane
    must fit in an ae9* engine bay
So far im thinking along the lines of
silvertop block
8.5:1 gze pistons
ae92 rods
silvertop head with the throttle body manifold and a custom plenum attached to this
sc14 blower
link computer
standard boost or oversized crank pulley boost with compression added through head milling to get a good balance of boost and compression.
Anyone else care to add their opinion and recipe??
When in doubt, down and out.
soopachargen
Postby bluemaumau » Mon May 22, 2006 7:25 pm
not an expert on this but i thought the redtop block was good cause of the oil squirters, someone please shoot me ...........
Postby soopachargen » Mon May 22, 2006 7:27 pm
i believe the silvertop block has the squirters etc like the ae101 gze... and logic leads me to believe that a silvertop block would be cheaper than a gze one
soopachargen
Postby no_8wire » Mon May 22, 2006 7:40 pm
how about a megasquirt instead of link? Link doesnt run feedback apparently..eg 02 sensor
no_8wire
Postby soopachargen » Mon May 22, 2006 7:47 pm
link has more support, i like the idea of being able to send it back if i have a problem with it and having all the knowledge around. And there is supposed to be a guy in warkworth who tunes them well.
soopachargen
Postby RedMist » Mon May 22, 2006 9:07 pm
no_8wire wrote:how about a megasquirt instead of link? Link doesnt run feedback apparently..eg 02 sensor
You mean closed loop fuel control? Even the most basic LEM does. The LEM however doesnt have knock control. The plus has hardware for knock detection, and would presume it has software for closed loop ignition control.
I think you'll find considerably more inputs and outputs in the plus, especially the G2, than the megasquirt. That may change dependant on how the megasquirt v3 board space is eventually populated. But for now the link, IMO, is a considerably better option.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Caveman » Mon May 22, 2006 10:39 pm
That all sounds pretty good
Silvertop block
8.9:1 ze pistons
smallport rods
bigger crank
silvertop head
custom plenum
itb's
sc14 before the tb's
higher boost pully
E58 lsd box
link ecu
440cc injectors (3sgte should fit nicely)
full regrind and rebuild
that would be my dream car 8)
Caveman
Postby no_8wire » Mon May 22, 2006 10:42 pm
Oh...well not according to the guy that I spoke to...and he sells them for a living...
Said all the ones hes tuned/ setup havent had the provision for them.
But hey he just sells and tunes them, what would he know
no_8wire
Postby strx7 » Mon May 22, 2006 11:14 pm
a properly tuned system doesn't need closed loop O2 anyway. its about getting off ones @rse and spending some time to tune the crusing & around town zones, not difficult.
Postby Lloyd » Mon May 22, 2006 11:26 pm
http://www.linkecu.com/products/engine- ... ire-In/LEM
Paying special note in the features to "Configurable closed loop narrow band lambda control."
Postby matt dunn » Mon May 22, 2006 11:30 pm
no_8wire wrote:Oh...well not according to the guy that I spoke to...and he sells them for a living...
Maybe not a lot then.
I run my old V3 link lem ( 1999 model ) and hooked up a new narrow band oxy sensor and let it self tune the entire program at the track.
Run it like that for a year and no problems, so proof that they have o2 input and it works.
Ask him what the white wire in all the link ECU's labelled O2 if for?
Matt
Re: what parts to build the ultimate 4agze
Postby crnkin » Mon May 22, 2006 11:48 pm
soopachargen wrote:
silvertop block
8.5:1 gze pistons
ae92 rods
sc14 blower
link computer
Number 1, you cant get stock 8.5:1 toyota gze pistons, either 8.9:1 or 8.0:1 but thats a minor issuse.
Number 2, whats your budget? Do you already have the sc14? I know of a guy in the states who developed a kit using a twin screw supercharger similar in size to the sc14 but more efficient, which produces around about 400 rwhp on a bigish pulley (21psi)
number 3. Ae92 rods: out of what engine? there were 4 types of rods produced in ae92 4ages
A silvertop block is just as good as a redtop smallport as they are the same down to the oil squirters
If you have some time to play and can work with simple electronics id go megaquirt, there is nothing cooler i reckon than building something for your car and knowing you did it yourself, plus it has HEAPS of support, if not more than link, as you can just download updates at anytime, and people share maps online of everything.
But just my opinion :)
About that guy who tunes links no8_wire... Id never take anything to him if he cant even utilise closed loop on a link.... plus if hes calling it feedback... sounds like hes been smoking way too much P, and i actually mean it
deaf_homo "currrently yes"
crnkin
Postby bluemaumau » Mon May 22, 2006 11:52 pm
1998 wrote:That all sounds pretty good
Silvertop block
8.9:1 ze pistons
smallport rods
bigger crank
silvertop head
custom plenum
itb's
higher boost pully
E58 lsd box
link ecu
<*x*> *gizm*
Postby FXGTV » Tue May 23, 2006 2:24 am
Isnt a gze block diff from a n/a smallport? Means the gze can handle the sc. So wouldn't a silvertop block not be able to handle the extra stress of an sc14 being that silvertops are factory n/a.
Im a mechanical n00b by the way, so this might be a long shot :lol:
1988 r31 TI Skyline.
FXGTV
Postby soopachargen » Tue May 23, 2006 9:25 am
crnkin wrote:
soopachargen wrote:
silvertop block
8.5:1 gze pistons
ae92 rods
sc14 blower
link computer
Number 1... thanks for correcting me... i'm feeling the more compression the better...
Number 2... Im using toyota parts to keep it to a low budget build, if i went custom this and forged that the price would quickly get out of control. I'm already running an sc14 on my gze...
Number 3... by ae92 rods i meant reuse my afm gze rods or the ones from the tvis redtop i have sitting around
1998, i would run a big single before the charger with a water to air cooler sitting on top of the motor, iv gone from standard top mount to big front mount and prefer the throttle response of the short plumbing. The throttle before the charger works so im happy with it, and it means i dont have to worry about a BOV.
I've been told i may be better off getting an aftermarket LSD for my E52 rather than some used e58 box. Then i can rebuild my box and put the good diff in it knowing that it will all work.
soopachargen
Postby crnkin » Tue May 23, 2006 12:10 pm
ahhh sweet.
The tvis redtop rods are exactly the same as the GZE ones, with the exception of a small notch out of them at the big end of them on each side. With a polish and shot peen theyd be mint for this application.
And high compression rocks :)
crnkin
Postby Caveman » Tue May 23, 2006 6:19 pm
In that case it is very worth while running a tubular intake manifold with even lengths as the stock 4agze intake manifold is a joke.
Easy power to make.
Caveman
Postby RedMist » Tue May 23, 2006 7:09 pm
I dont think I would take my car to him. Although I dont use closed loop I've been logging O2 data from the Link to my PDA for some years. I've also run closed loop on one of my 20 valves. Its actually not a bad system. Has limits to ensure that a faulty sensor doesnt totally screw your map, and allows you to bypass those limits by doing a simple save.
Megasquirt is a very good basic system. I guess I'm a little pissed that the UMS didnt come out in 2003 when it was first scheduled. its also the fact that I've been playing with Link ECU's for years so am familiar with them. Also the software is stupidly easy to configure.
If you are a little more electronically minded the Genboard is a stupendously feature rich board but not for the timid.
In regards to compression. I ran an SC12 on a stock bluetop thats now Revheads car. Never heard the slightest pink from her and it was a reasonably quick wee AW11. Still that was stock boost.
RedMist
