te71 crossmember into ke70 = excessive toe out?
Postby tbag » Tue May 23, 2006 11:24 pm
Right the te71 crossmember is in the car as is engine box and diff.
I am still running the original ke70 front struts bottom ball joint, bottom arms and steering box and steering arms.
As it sits now it looks as though putting crossmember in and bolting up bottom arms has made wheels toe out somewhat excessively. :?
I know that the te71 front struts and bottom ball joint/steering arm mount are different between ke70 and te71.
What i am wondering is whether the bottom arm itself is the same in both cars and if so are the bottom arm mounts between crossmembers different??
Or since i have the te71 crossmember do i have to run an entire te71 front end? :?
tbag
Postby Lloyd » Tue May 23, 2006 11:40 pm
May seem like a stupid question... but why not just adjust the toe?
Postby fangsport » Tue May 23, 2006 11:42 pm
fit longer lower control arm from a TT132 Corona and get the benefit of more camber??
or adjust the toe :(
fangsport
Postby tbag » Tue May 23, 2006 11:45 pm
EXCESSIVE TOE OUT!!! :lol:
Im not that blond come on!!! :lol:
tbag
Postby Jebus » Tue May 23, 2006 11:50 pm
Adjust it excessively
Jebus
Postby fangsport » Tue May 23, 2006 11:54 pm
tbag wrote:EXCESSIVE TOE OUT!!! :lol:
define excessive?
are you using the TE71 steering rack (not that it should matter)?
have you gained/lost camber?
are you sure its a TE71 x-member?
fangsport
Postby tbag » Tue May 23, 2006 11:54 pm
Yes that could be done but would probably mean extending steering arms?
Then again i should really try it before saying im not blond eh?
Guess ill do that but would like to know how the toe out came about....
tbag
Postby tbag » Tue May 23, 2006 11:55 pm
One wheel straight and the other say out by maybe 10 deg
tbag
Postby fangsport » Wed May 24, 2006 12:03 am
tbag wrote:One wheel straight and the other say out by maybe 10 deg
what about the rest of the Q's
fangsport
questions
Postby tbag » Wed May 24, 2006 12:17 am
everything else apart from crossmember the original ke70 items (front struts ball joints steering and bottom arms) and it a steering box.
no visible increase in camber
tbag
Postby fangsport » Wed May 24, 2006 12:36 am
eeeeeeeeeeewwwwwwwwww shitty old steering box.........throw it away and fit rack and pinion 8)
there should be heaps of adjustment on the tie-rod ends to correct the toe, if there isn't, get the adjusters from a TT132 Corona or a TR?? Lite-ace van(circa 1981).
fangsport
rack
Postby tbag » Wed May 24, 2006 12:58 am
hmm will try adjustment
crossmember has no brackets for rack and pinion...
thankx
tbag
Postby AE85coupe » Wed May 24, 2006 6:19 pm
o.k, i have a total of three mates that have te71 crossemembers in there ke70's and not one has had any excessive toe out that can't be easily corrected
AE85 Trueno *For sale*
Details of car here
AE85coupe
