4agze wont rev over 2500
Postby XSVWGN » Wed May 24, 2006 2:00 pm
well the wagon has been off the road for nearly a year now and i really want it going. It starts, the timing is correct and all the piping is ok etc but... it wont rev over 2500rpm? any ideas?
Its very frustrating i have to walk everywhere and i have a $10,000 sitting in the garage
Matt
027 459 0038
2008 Kia rio - work car
XSVWGN
Postby slighty_sykotic » Wed May 24, 2006 3:36 pm
When it gets to 2500 rpm, what do it do?
Its almost sounds like a really bad limp home mode on the ecu, but i don't think limp home mode on toyota's is that low? (the rpm limit).
Checked for fault codes?
--Sykotic
slighty_sykotic
Postby bluemaumau » Wed May 24, 2006 6:41 pm
get it going au
Postby XS1V » Wed May 24, 2006 8:34 pm
Yea sounds like its in limp mode. Is the engine check light up?? How is it running?? Rich?
Brad
ST205 Group A Rallye #2363
XS1V
Postby RedMist » Wed May 24, 2006 8:43 pm
Sounds more of a timing issue. Limp home mode doesnt restrict you to 2.5k.... not in the machines I've seen with a engine warning light on.
What exactly does it do? Take forever to hit 2.5k? Rev build slowly? pop? burp? fart? knock? tick? Smell like Revheads goats?
... tell us more!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby YeMs » Wed May 24, 2006 10:17 pm
u say the timing is correct. u talkin spark timing or belt timing?
Your local Hybrid Elite tech
YeMs
Postby FLAWLES » Thu May 25, 2006 12:47 pm
i was bout to say that
have you made sure that your cam timing is spot on?
or if you have the crank angle sensor in the right place
been there done that
cause i had the cam timing off by a wee bit and the crank angle sensor all wrong
it would rev but to about 3 then it would chuck all its toys out of the sand pit
re check everything
FLAWLES
Postby XSVWGN » Thu May 25, 2006 1:50 pm
both the timing on the crank andgle sensor and crank timing are right. It revs to 2500 them with the accelerator down it churps....'revs to 2500 then dies to 1000ish then up to 2500 again. The check lights in the dash are not coming on. Possibly a wireing fault in the dashboard. After a few minutes with the car on it dies. Its really $&#$% annoying.
Any1 know wot could be wrong?
XSVWGN
Postby rallyrulz » Thu May 25, 2006 10:27 pm
mmm, sounds a bit like mine. Im starting to see many posts about 4agze right about now and there electrical problems. Sadly mines still at the garage after over a month! And i know its going to be one expensive repair job... What he has found however has been everything from low voltage to presumably the fuel pump relay which caused it to intermitantly cut out, I think that was caused by someone doing bad wiring somewhere. The map sensor earth aparently had a bad connection, and now hes found low voltage to the fuel pump...
Symptoms were randomly spluttering and then stalling, engine light did come on however. This was an extremely intermittant problem however.
I guess you have tried resetting your ECU by taking off the battery? Usually puts it back to normal for atleast the 1st minute.
rallyrulz
Postby XSVWGN » Fri May 26, 2006 12:11 am
that is the exact same problem i am having. There is 0.4v to the fuel pump. It splutters then stalls... I have tried resetting the ecu but it doesnt make a difference...
...can anyone help? its driving me nuts!!! i want it going
XSVWGN
Postby XSVWGN » Fri May 26, 2006 9:59 pm
bump bump bump
XSVWGN
Coff... choke....
Postby jondee86 » Fri May 26, 2006 11:26 pm
Assuming that the fuel circuit wiring in an AE92 GZE is similar to an
AE92 NA, then the fuel pump gets 12 volts from the Circuit Opening
Relay. The COR gets 12 volts from the EFI Main Relay, which in turn
gets 12 volts from the battery.
There are two coils in the COR. The first one is energised when the
key is in the "On" position. You should hear the COR (and the EFI Main
Relay) click, and the fuel pump running. If the pump is not running,
then try to confirm you have an operational pump.
The second coil is activated when the key is in the "Start" position.
Disconnect the starter solenoid wire and turn the key to "Start". You
should hear the COR click and the fuel pump running.
Easy enough to pull the COR and see what voltage you have on the
pins. Either way, 0.4 volts at the pump won't do anything.
Cheers.... jondee86
Watch this space >>> <<<
jondee86
Postby THA SHZ » Sat May 27, 2006 5:56 pm
bluemaumau wrote:get it going au
now that was a really helpful response , moron :roll:
does sound likea little dodgy wiring , why dont u give nick (nz_ae86) a pm as he is quite a good auto sparkie and i presume hes still living around your ways 8)
THA SHZ
Postby bluemaumau » Sat May 27, 2006 7:49 pm
personal joke dude
Postby Psycho_Dad » Sun May 28, 2006 10:50 am
check your afm, their may be a loose connection their or somthing, well it sounds similar to what problems i had and that was the solution...
a little wiggle can take you a long way
Peace
Psycho_Dad
Psycho_Dad
Postby XSVWGN » Sun May 28, 2006 8:44 pm
fantastic guys. Will try what you have sugested and if anyone thinks it maybe something else then please email me etc
Matt
XSVWGN
