Diff ratios etc - basic questions..
Postby dxtawagon » Mon May 29, 2006 6:34 pm
what are the ups and downs of changing my low ratio diff (F252 = 4.55 - 1) to a 4.1 or 3.9 or something??
im wanting lower revs when open road driving as my car is just for cruising and at the moment it revs really high even in 5th.
i dont have a rev guage so i did a few measurements and numbers and worked out that at the moment it runs about 3600rpm at 100km.
that is based on a 4.55 diff and i think 0.85 in 5th (w55 gearbox) and the diameter of my wheels approx 585mm.
then if i substitute a 3.9 diff it works out about 3100rpm.
which seems better. but is that to much of a change from standard???
also will a IRS F series diff fit into a solid rear axle?? or what needs to be done to change it over???
daniel
dxtawagon
Postby dxtawagon » Wed May 31, 2006 2:12 pm
bump
dxtawagon
Postby Stealer Of Souls » Wed May 31, 2006 2:44 pm
I would think that going for a 3.9 isn't a major issue for the car. Providing that you're just driving it and not racing it. If the engine is standard it should handle the ratio change fine.
Good:
Improved mileage when cruising at speed.
Reduced noise at speed.
Bad
Speedo will not be correct.
Indifferent:
Will make the car accelerate slower.
For a street car the change would be fine in my opinion.
'86 AE85.5 Levin
Stealer Of Souls
Postby dxtawagon » Thu Jun 01, 2006 5:02 pm
sweet cheers
thats kinda what i figuered
anyone know whether IRS diff head can go into solid rear housing??
dxtawagon
