running motor in on dyno
Postby deaf_rattle » Mon May 29, 2006 8:25 pm
once the 7mgte is rebuilt ill be running it in on a dyno, has anyone done this? im expecting it to take an hour, as the first 20mins are the most critical.
how much roughly should it cost?
Going to start ringing around, but probably not till closer to the time
Postby MrOizo » Mon May 29, 2006 9:09 pm
how about a running in cruise? :P
i need to be doing the same.
say hamilton and back? ;)
MrOizo
Toyspeed Legend
Postby deaf_rattle » Mon May 29, 2006 9:13 pm
lol, would sound like a plan, but My mate thats doin the rebuild is saying dyno time is the best way to run it in, and by that stage whats another couple of hundy
Postby MrOizo » Mon May 29, 2006 9:53 pm
awwww worth a shot.. - anyone else? :P
MrOizo
Toyspeed Legend
Postby MetalupYoAss » Mon May 29, 2006 9:57 pm
no way keep it off the motorway, you need to vary the revs and keep load on the motor!
MetalupYoAss
Postby 85AW20v » Thu Jun 01, 2006 10:22 pm
So a build up to full race speed over 15 laps at Taupo should have been about right after rebuilding the silvertop?
You could drive through the suburbs until you get to some of the Targa roads around Huntly which will certainly give you variations in revs - a bit like Murph did on his way to Huntly for the celebrity races!!
See ya
Simon
85 MR2 20v
85AW20v
Postby CMS » Thu Jun 01, 2006 10:25 pm
Hope so, it's what i did with the esky.
Comber Motor Sport
"If you're not living on the edge, you're takin' up too much space!"
CMS
Postby postfach » Fri Jun 02, 2006 7:29 pm
i think the dyno at high velocity is $120 an hour, but you'd have to call gavin and check
postfach
