gearbox oil / sensor Q
Postby bluemaumau » Tue May 30, 2006 1:23 am
ok im gettting to a finished stage with the wagon now (touchwood)
when i get the dash loom in i wont be able to refrain from taking it for a drive.! :P
was talking to a toyota mechanic today, he told me to check if my car needed gbox and diff oil. i dont think it does as it only had one outlet.
but if anyone could clear that up it would be awesome.
box is e52 non lsd
also ive run into trouble with the spedo drive. ae92s are cable, and my cars ae101 = problem,
so i doubt ill have a speedo drive for a while so this brings me to another question.
if there is no speedo drive in the gbox will gbox oil piss out of this hole, or is it a completely different place?
btw e52 speedo drives are horizontal.
Postby slighty_sykotic » Tue May 30, 2006 11:36 pm
It will need oil. If you drained it you will need to put it back in.
And if you take the speedo drive out, yeah oil may leak. At worse maybe block the hole with something?
And dude, maybe you shouldnt take it for a drive until it's done......
Been there, and done that...don't want to do things half assed...
--Sykotic
slighty_sykotic
Postby bluemaumau » Tue May 30, 2006 11:47 pm
yea i know it needs oil! :lol:
just wondering if theres 2 compartments or just 1?
yea ill just put the cable speedo in to i find a electronic one. :roll:
ill try and resist :wink:
Postby slighty_sykotic » Tue May 30, 2006 11:51 pm
lol, i read your post wrong...
Nah, just one compartment.
--Sykotic
slighty_sykotic
Re: gearbox oil / sensor Q
Postby Jebus » Thu Jun 01, 2006 1:00 pm
A mechanic at toyota told you that?
Jebus
Postby Mr Revhead » Thu Jun 01, 2006 1:46 pm
yes as some eseries boxes as found in the camry and corona etc had seperate diff oil
to tell have a look on the drivers side of the diff housing, if it has a drain and a filler bung above it its seperate. however as yours is supposed to be from a levin/trueno it wont have
Postby bluemaumau » Thu Jun 01, 2006 2:02 pm
Mr Revhead wrote:yes as some eseries boxes as found in the camry and corona etc had seperate diff oil
thanks warwick.
Postby Mr Revhead » Thu Jun 01, 2006 3:36 pm
actually it could be the back of the housing.... but you get the idea!
been a while since iv been under one!
Postby bluemaumau » Thu Jun 01, 2006 3:57 pm
Mr Revhead wrote:actually it could be the back of the housing.... but you get the idea!
what so it does have one? :?
Postby Mr Revhead » Thu Jun 01, 2006 4:47 pm
no sorry i meant the camry/corona ones that do have seperate diffs.
the gtz box doesnt
Postby Alex B » Thu Jun 01, 2006 4:53 pm
The E55F5 in my AE95 has 2 seprate drain holes, one on the diff, one on the gearbox, but when you fill the gearbox it fills the diff too.
Postby bluemaumau » Thu Jun 01, 2006 5:21 pm
sweet as thank you all
