Toyota Supra GA70 Mags
Postby Sideros » Tue May 30, 2006 11:02 pm
Hey guys, looking to fit a set of GN+s onto my supra... 18x9.5 rear and 18x8.5s front. Anyone got any info on what I need to adjust to get the tires under the guards? The guys at Mag And Turbo don't seam much help...
Sideros
Signwriter
Postby Quint » Wed May 31, 2006 11:58 am
Not sure wat 9.5" is in metric, but i have 255 tyres on the back of my car, they don't really fit under the gaurds :(, The 235s on the front are probably the largest i'd go if i was to buy another set.
Tryed to do the cheap put a 'jack in the wheel well' and jack it out real slowly but the rear 1/4 panel looked like it would suck itself in so gave up, local panel beater also gave the same response, would probably have to go to a specialist shop to get them flared but don't know of any/worried bout the $$ they'd ring up.
Hope that helps.
Quint
Postby MrOizo » Wed May 31, 2006 12:11 pm
I had ROH Drift-R's on my supra. Was 19x8's with 235's on the front and 19x9's with 265's on the back
had no worries wih rubbing or not fitting what so ever!
might just have to make sure you get the right off-sets!
MrOizo
Toyspeed Legend
Postby Quint » Wed May 31, 2006 12:35 pm
Hmmm, the offset on my set is right (sit about 5 mm out from the spring capture) and they sit a fair bit out from the gaurd (enough so putting it inside the gaurd would easily make it rub against the spring).
Mr Oizo isn't yours an JZA? maybe the gaurds are a little wider than the '86 GA-70?
But then again, i could have just $&#$% up :D
EDIT: Did a little bit of reading and:
GA-70: Length / Width / Height (mm) 4620 x 1690 x 1310
JZA-70: Length / Width / Height (mm) 4620 x 1745 x 1300
Quint
Postby MrOizo » Wed May 31, 2006 1:29 pm
Oops my bad.
didnt think about the supra in question being a non wide body - my bad :oops:
:P
MrOizo
Toyspeed Legend
Postby Quint » Wed May 31, 2006 1:37 pm
Not everyone has flashy flareing...
Not that i want it or anything....
*crys about his straight body supra*
Quint
Postby postfach » Wed May 31, 2006 11:18 pm
i dont know how similar they are but i have a gz20 soarer and ive got 18x9.5 on the rear with 255/40 tires, fits fine
postfach
Postby RED TOP MR 2 » Fri Jun 02, 2006 3:09 pm
if it hits the guard jus get the classic baseball bat unda the guard and roll the car forward
RED TOP MR 2
