7afe---Ignition? Coil or dizzy...Which is best?
Postby no_8wire » Thu Jun 01, 2006 9:23 am
Now I have been ringing around, and have been offered two 7afe engines for the same price...how ever one uses coils, eg has crank angle sensor, and one is just a normaly dizzy type...
Any advantage of one over the other?
Can a link run with a crank angle sensor?
no_8wire
Postby Bazda » Fri Jun 02, 2006 12:13 am
i would say the later model could be the coils...
Also you will be using a diff head so it wont matter, if u use a 20v head u will use the 20v dizzy etc
yup
Postby ezy10s » Fri Jun 02, 2006 1:28 pm
both bottom ends are the same so just go for the one with the leasty amount of miles on it.
Member #244
ezy10s
