Gauges - where to mount senders
Postby z|gen » Thu Jun 01, 2006 1:14 pm
hey guys,
just after a bit of info as the instructions dont really tell me anything.
need to know the location of the mounting points for the senders of an Oil pressure gauge and also a water temp gauge on a bluetop tvis 4age.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Jebus » Thu Jun 01, 2006 1:18 pm
Oil pressure is on the exhaust side of the block, nearer the timing end half way up, its the steel diaphram lookign thing I suppose youd call it. when ya run the feed, make sure its a metal one, and run it around the front of the motor with the dizzy wiring otherwise you might find it will catch burst and catch fire from the heat of the extractors.
The water temp is above the water pump in the casting with the radiator hose outlet on it, at the timing end of the motor.
Have a search, ive posted pics up before of the locations.
Jebus
Postby 2LTR Rona » Thu Jun 01, 2006 1:28 pm
Bluetop with TVIS going through rebuild......
Oil Pressure Sender (inside red box)
Temp Sender (inside red box)
2002 Altezza, 1974 KE25
2LTR Rona
Postby z|gen » Thu Jun 01, 2006 1:31 pm
sweet, thought the oil pressure was there, but wasnt sure.
cheers for the help :)
z|gen
Postby aesc » Thu Jun 01, 2006 3:03 pm
For water temp I'd get a a hose adaptor made so the sensor can be tee'd into the heater hose, thats what I've just done.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby z|gen » Thu Jun 01, 2006 3:07 pm
dont have heaters..
but i think i need to make up a new adapter anyway, the ones that came with the gauge are both the wrong size :(
z|gen
