heads and blocks are all interchangable. Although some will require mods to get all the external bits to hook up...Hachiroku wrote:Is there any difference between the two? Will a 16v head go straight onto a 20v block? Its for rwd so I don't want to dick around with water pipes, dizzy etc. but I do want high compression and stronger bottom end.
