Accerator hard to push in AE101 suddenly....
Postby DB4G63 » Sun Jun 11, 2006 3:35 pm
Im not sure if this is a big problem or not but it is certainly making the car very hard to park and do hill starts in effectively...
The accelerator is hard to push to start with, but suddenly becomes easy after about the first 15% of the peddle. however it feels like it isnt going to move until I give it decent force..... which means you have to push harder than normal
It only began happening today, and its very noticable.
What would suddent make this happen? Can it be adjusted?
Im not sure whats going on here :?
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby CozmoNz » Sun Jun 11, 2006 3:44 pm
Have a look at the throttle cable in the engine bay, may be snagged slightly, maybe a bit of greese on it? who knows, but there must be a reason
also have you done any work around the throttle area?
Rayne For President!
CozmoNz
Postby bluemaumau » Sun Jun 11, 2006 4:09 pm
check that the i/c cover isnt $&#$% with the cable
Postby Santa'sBoostinSleigh » Mon Jun 12, 2006 11:14 am
cable might be on the way out, may be frayed or similar.
also check around your pedal and the cable housing, may be catching on something?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby THA SHZ » Mon Jun 12, 2006 6:13 pm
Open your throttle body , and clean around where the butterfly for the throttle is as this gets cloged up and makes it stick sometimes
THA SHZ
Users browsing this forum: No registered users and 22 guests
