Building a 4AGZE exhaust system, good flow but low noise
Postby Rick » Tue Jun 13, 2006 6:33 pm
Iam starting to look at an exhaust system for my AE-85 which has a 4AGZE in it. Iam wanting a good flowing exhaust but with minimal noise, I dont want any raspy sounding exhaust. I already have extractors on it, which I have welded on a 2.25 flange on it, but is that a bit on the small side? Do I need to jump up to 2.5inch?
Can some point me in the right direction and recommend the types of mufflers, good brands etc.. which would be a great help.
Postby bluemaumau » Tue Jun 13, 2006 11:05 pm
hey man i got 2.5 mandrel with rps bling cannon :roll: . nice and quiet too. still a tiny bit raspy(nowere near as bad as 20v) but im pretty sure that raspy nice is a toyota trait! :(
Postby Jazza » Tue Jun 13, 2006 11:08 pm
HKS is good for flow from what ive heard, noise factor i dunno about. Dont get an RPS :P
1996 Curren - On Tardme
Jazza
Postby bluemaumau » Tue Jun 13, 2006 11:11 pm
yea RPS just sounds gay, but im pleasently surprised with mine. really quiet
Postby soopachargen » Wed Jun 14, 2006 6:29 pm
use a proper "turbo muffler" from an exhaust place... they sound mint... but you dont have the added magpie bait that people are after...
When in doubt, down and out.
soopachargen
Postby Rick » Fri Jun 16, 2006 6:37 pm
soopachargen wrote:use a proper "turbo muffler" from an exhaust place... they sound mint... but you dont have the added magpie bait that people are after...
so just one "turbo muffler" will be fine?????
Postby Stealer Of Souls » Fri Jun 16, 2006 10:33 pm
I've generally avoided these things....
http://www.geocities.com/srsvengence/ts_tech/0383.xls
http://www.geocities.com/srsvengence/ts ... 81_pt1.pdf
http://www.geocities.com/srsvengence/ts ... 82_pt2.pdf
http://www.geocities.com/srsvengence/ts ... 83_pt3.pdf
This is a test done by Autospeed.com.au. I'll admit it's not the be all and end all.
But it does illustrate a few points.
Not all mufflers are the same.
Some of those "turbo" mufflers contain two dog leg turns which have an absolutely terrible flow rate, and some of those don't even do a good job at actually silencing the exhaust.
Check out the top five contenders in this test. The 2 inch Genie Tornado, not only flows more than a 2 inch pipe (obviously not actually 2 inch internally, but sold as a 2 inch) but is about the fifth best at noise reduction.
IMO.
If you want a good exhaust. Pick a pipe size. Then buy a cat, a resonator and a muffler that are at least a 1/4 inch bigger in diameter. Slap the bugger together and enjoy.
Make sure to pick components that actually are all straight through. If you can't see out the other side it ain't good enough.
'86 AE85.5 Levin
Stealer Of Souls
Postby Jazza » Sat Jun 17, 2006 7:35 am
Stealer Of Souls wrote:IMO.
Thats a pretty good rule of thumb. Id go with that too. Make sure you got clearence under your car too obviously, cos you dont want rusty holes in the bottom.
Jazza
Re: Building a 4AGZE exhaust system, good flow but low noise
Postby Caveman » Sat Jun 17, 2006 11:59 am
Rick wrote:Iam starting to look at an exhaust system for my AE-85 which has a 4AGZE in it. Iam wanting a good flowing exhaust but with minimal noise, I dont want any raspy sounding exhaust. I already have extractors on it, which I have welded on a 2.25 flange on it, but is that a bit on the small side? Do I need to jump up to 2.5inch?
I thought you had that badass looking bolt on kit? Whats wrong with that?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Rick » Sat Jun 17, 2006 1:41 pm
1998 wrote:I thought you had that badass looking bolt on kit? Whats wrong with that?
Yeh I test fitted it the other day and it hits the hilux diff, bit of a bugger.
Postby deaf_rattle » Sat Jun 17, 2006 2:16 pm
i wouldnt go to 2.5" unless going turbo later...
2.5" was fine for 3l turbo motor.....
i would use at least one straight through resonator half way down the exhaust and a super turbo style at the back.
Or super turbo half way down and cannon style at the rear..
Postby Rick » Thu Jun 22, 2006 8:19 pm
So only two mufflers? sounds like it will be loud, who sell's these "super turbo mufflers"?
Postby deaf_rattle » Thu Jun 22, 2006 9:47 pm
hey
Even the exhaust on my fxgt isnt too bad, only 2" i think rps non straight through muffler at the back and straight through resonator in the middle
if you are out my way at some stage pop round and ill take you for a ride.
However the set up in the supra is far nicer and i actually played around with a couple of different resonator/muffler set ups
the super turbo muffler i got is from repco, and the straight through cannon style muffler is an action dan special.
Postby Jebus » Thu Jun 22, 2006 10:14 pm
You cant use what youve got? just modify it to go under the diff? How much clearnace between the floor and diff head have you got? Ive got about 15mm in the centre :( in my KE30 with Hilux rear, so just went under it, certainly not a bad option, especially if you already have a pre-made system.
Jebus
Postby postfach » Sat Jun 24, 2006 12:18 am
als mufflers sell those non-bling turbo mufflers, as do most other exhaust places i guess. i got mine done there and its got a pretty nice sound imo, not too expensive either.
postfach
