4age breather
4age breather
Postby Caveman » Thu Jun 15, 2006 9:08 pm
Do 16V 4age run a pcv valve? I couldnt find one on mine :?
Also whats the correct way to run a catch can with a turbo motor?
Is it cams > catch can
then catch can > pcv valve > manifold
and catch can > air intake (before turbo)
If so where is the vacum produced during boost for the crank case?
AW11 Track Toy
Formerly known as 1998
Caveman
Re: 4age breather
Postby gepsk8 » Thu Jun 15, 2006 9:18 pm
pcv can fck out stuffing ur motor or turbo
Is it cams > catch can > fresh air through filter if wanted
no pvc valve on n/a engine as far as i know
gepsk8
Postby Crucible » Thu Jun 15, 2006 9:55 pm
Just run the hose from the rocker cover into a catch can with a filter. N/a engines can run a vacuum line from the can but on a turboed engine its a little differant because boost will pressurise it, If you also ran the line into the manifold via R/C, boost would also pressurise the crankcase. As long as the crankcase can release pressure from blowby easily it will be fine without vacuum purge.
Rocker covers ->Catch Can ->C/Can Air filter :lol:
Crucible
Real Life Mechanic
Postby Caveman » Thu Jun 15, 2006 11:45 pm
True-No-Turbo wrote:Just run the hose from the rocker cover into a catch can with a filter. N/a engines can run a vacuum line from the can but on a turboed engine its a little differant because boost will pressurise it, If you also ran the line into the manifold via R/C, boost would also pressurise the crankcase. As long as the crankcase can release pressure from blowby easily it will be fine without vacuum purge.
Thats what the pcv valve does, its like a 1 way valve. I guess it will be fine just going from the cams > catch can > turbo inlet as its pretty much the same as stock 8) Dont want to vent to atmosphere cos the fumes
AW11 Track Toy
Caveman
Postby aesc » Fri Jun 16, 2006 2:10 pm
Apparently they dont use a PCV valve, or so crispy86 was telling me the other day.
Basically you want the catch can to run in between the cam cover and the intake plenum, there is a short length of hose connecting the 2 on the factory setup.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Crucible » Fri Jun 16, 2006 3:07 pm
1998 wrote:Thats what the pcv valve does, its like a 1 way valve.
PCV valves on n/a engines only let vacuum purge the crankcase on W.O.T, they block flow on idle as not to allow unregulated air into the manifold. I would of thought that it wouldnt be very effective on a Forced ind/engine as it would be closed on idle and also would have to be closed on boost. Maybe pcv's are a differant type valve on factory turbo motors? Wouldnt a line running from the catch can to the turbo air duct cause fumes to forced into the intercooler via Turbo? Wouldnt it cool and condense back into oil, leaving residue in your cooler and ducting? I thought about this when doing my shitt*, thats why I just vented to atmo?
I dunno just my thoughts! :lol:
Crucible
Real Life Mechanic
Postby sergei » Fri Jun 16, 2006 3:27 pm
Turbo engines produce lots vacuum under engine braking and very low throttle. So generally PCV valve would work on turbo car.
Users browsing this forum: Bing [Bot] and 26 guests
