Z-master wrote:sorry to dredge up an old thread, but thanks for the info, haha i failed my WoF for no airbag light too. Cheers!
Just to confirm, my dash has an airbag light on it, but it won't work, is that correct? (just triple checking)
Dell'Orto wrote:Actually I came across this the other day...yes, the cars do have a spot on the dash for an airbag light, but removing the dash reveals no wire actually going to the plug to make it light up, funnily enough being mechanical. The car was a 96 AE111 with 4AFE, single airbag
Z-master wrote:Not sure if its any interest, but its a 111 prefacelift trueno (1996)
astrae wrote:While I'm having a bit of a bitch about VTNZ there is one other thing they said that pissed me off.
The reason I went there was because my 5mm rear wheel spacers never went on my cert plate when the suspension was certed 2 months ago (plate makers stuff up) Things have been taking a while so I thought id get a quick warrent (never again..) to hurry them up a bit.
3 goof balls at vtnz all agreed that wheel spacers could not be certed and i'd have to take them off...
Well my new plate thats arriving on Monday has got them on it....
wankers
Rick wrote:Dell'Orto wrote:Actually I came across this the other day...yes, the cars do have a spot on the dash for an airbag light, but removing the dash reveals no wire actually going to the plug to make it light up, funnily enough being mechanical. The car was a 96 AE111 with 4AFE, single airbag
Not a 100% true, it maybe the case for that car, was it a station wagon? perhaps its a 4AFE thing? I own two AE111 BZG's both preface-lift both with single airbags and both the dash clusters do not have an airbag light what so ever, no spare spot or anything.
tsoob wrote:astrae wrote:While I'm having a bit of a bitch about VTNZ there is one other thing they said that pissed me off.
wankers
if they are 5mm floating spacers they not ment to be certed
Section 3 Modification and repair wrote:
3.1(3) The fitting of wheel spacers to a vehicle is a modification that requires certification, unless the vehicle, wheel or axle manufacturer approves their use for a particular vehicle.
205-00(00) Wheels and Tyres wrote:
2.5 Wheel spacing and adaptation requirements
Spacer requirements for all wheels
2.5(1) A wheel spacer fitted to a low volume vehicle between the wheel and hub assembly, other then that fitted as original equipment by a high volume vehicle manufacturer, must:
(a) have a maximum spacing of each wheel away from the hub surface of 20mm; and
(b) be set-screwed or attached by another secure method to either the wheel or hub face; and
(c) Be manufactured from a solid block of suitable material; and
(d) have two machined or die-cast surfaces that are parallel, and contain minimum indentations or irregularities; and
(e) be fitted to ensure the wheel locates snugly over the hub spigot so that the hub carries the weight of the wheel assembly instead of the wheel studs, or where the is a mis-match between the hub spigot and the wheel centre, a close tolerance fit center bore locator must be provided; and
(f) maintain, with the spacer fitted, not less then the minimum required amount of wheel stud or bolt engagement specified in 2.4(4).
