Dragger_Dan wrote:Sorry I can't help with more fact, but I will tell you a few things I have noticed. Firstly that when I have unplugged my ECU and let it reset it _seems_ to run a little richer, especially at idle, but then comes back to normal by the time I have taken it for a quick drive. I have been able to notice this because sometimes it even backfires when I have just reset the ECU.
matt dunn wrote:For an ECU to self learn, first it must know if it's too rich or too lean,
and if your car is NZ new with no oxy sensor then how will it know???
I very much doubt it will have any learning ability at all.
Matt
RomanV wrote:Well there you go... There's no way it's going to learn anything, without either a knock sensor or oxy sensor.
remember any "learning" ability is within tight limits
build up a map of sorts over time.
