Fwd toyota handbrakes suck..why?
Postby ~SlideWays~ » Thu Jun 22, 2006 1:14 pm
Both my ae92 and my brothers ep82 have reallllly crap handbrakes.
Even my ae86 has a crap handbrake.
Why do toyota's have such crap handbrakes??
I've tried different pads, new centre cable on the ae92 and adjusted the lever. It barely holds the car, if there is a slight slope it won't hold it at all.
Is it stretched cables or what?
~SlideWays~
Postby Adamal » Thu Jun 22, 2006 1:22 pm
The handbrakes in both my MR2's suck. I can't even park in my own driveway cause its too steep!
Postby 2LTR Rona » Thu Jun 22, 2006 1:28 pm
Hmm same thing in the Corona as well, from memory they (Corona) are set at about 6 or 7 clicks from factory and do require adjusting from time to time & they are a right royal PITA to adjust from inside the cabin too :twisted:
I know that dont help, but yes it seems to be quite a common thing
2002 Altezza, 1974 KE25
2LTR Rona
Postby neo » Thu Jun 22, 2006 1:29 pm
Park facing down-hill. Thats the only way my 101's will sit on the driveway.
neo
Postby deaf_rattle » Thu Jun 22, 2006 1:31 pm
my ae92 fxgt could bearly do handbreakies, failed its wof because the hand brake cable had too much slack in it.
tightened it up in the cabin, handbreakytastic. :lol:
Postby sergei » Thu Jun 22, 2006 1:32 pm
Although I have no problems with steep drive ways, in both of my cars handbrakes are crap for doing handbrake turns, it works great as just park brake. They need adjusting and sometimes cleaning/lubing the the screw/ratchet mechanism as most of the time it siezes up and that is why they don't hold on steep roads.
Postby Leon » Thu Jun 22, 2006 2:38 pm
AE82 GT was bad, AW11 was shocking, but strangely the AE92 is actually not bad. It's not great, but it isn't useless.
Postby Jebus » Thu Jun 22, 2006 3:11 pm
Ive got VR4 calipers and handbrake setup and mine still sucks :(
Jebus
Postby Drifter4ag » Thu Jun 22, 2006 4:39 pm
i rang GX71 callippers & discs with Hydro ebrake and it was freaking awesome !!!
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby crnkin » Thu Jun 22, 2006 4:41 pm
E-BRAKE!
deaf_homo "currrently yes"
crnkin
Postby pc » Thu Jun 22, 2006 5:44 pm
mine's crap also. The only thing I can think of is to put rear pads in that work really well when cold. Might stuff up the front/rear brake bias when cold though.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby RedMist » Thu Jun 22, 2006 5:58 pm
You guys have just been yanking your shaft too long and too hard.
My MRS one works perfectly.... stops me every time.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby B1NZ » Thu Jun 22, 2006 6:19 pm
Mine was crap till Gold_AE86 adjusted it, now i nearly go through the windscreen doing handbreakies :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Jazza » Thu Jun 22, 2006 6:26 pm
Mines mint. Its just my tires that suck sh*t :P
1996 Curren - On Tardme
Jazza
Postby l1ttle_d3vil » Thu Jun 22, 2006 6:52 pm
my ke35 handbrake was sh*t until I replaced the diff with an ae85 setup. Although I kept my original handbrake cables, they were just setup so they were nice and tight with no slack anywhere.
they also had to be set up so they braked evenly; one side was pulling more than the other. now I can pull handbrakies easy!
Postby Emperor » Thu Jun 22, 2006 7:02 pm
Rav 4 handbrakes ROCK! :D
Emperor
Postby Rick » Thu Jun 22, 2006 7:02 pm
You will proberaly find that they are not that great becasuse they disk rear ends, drum brakes are good hand brakes/parking brakes, alot of biggger cars have disks for stopping and a internal drum brake for the hand brake/park brake
Postby Dell'Orto » Thu Jun 22, 2006 7:18 pm
My MR2's one wasnt bad, and the wagon's one is bloody brilliant. The sedan is a bit lacking atm, but thats just due to the cable being stretched to all buggery.
