Apexi Intake Cleaning..
Postby cespenar » Thu Jun 22, 2006 2:10 pm
Yes this is a bit of a n00b question and I've had a quick search, however since the Apexi filter is a dry-fibre type I didn't know if what I read would apply.
Basically, do you need to clean Apexi filters and if so whats the best way? I don't want to go putting water on it just to have it clump up the fibrous stuff and it doesn't need oiling - it also came from Japan so all the documentation is in Japanese. A lot of things I have found say they are almost maintenance free and last a lifetime but surely they'd need to be cleaned every so often?
cespenar
Postby AE82 FXGT » Fri Jun 23, 2006 2:09 pm
Is it this type?
http://forums.toyspeed.org.nz/viewtopic.php?t=41254
Probably just blow it with an air gun from the inside out, though I'm not a 100%.
AE82 FXGT
Postby RomanV » Fri Jun 23, 2006 2:24 pm
Yep they cant be cleaned, except for blowing out from the inside wit h an air gun.
Replace it, if it's really farked.
Although they're hardly cheap. :?
Postby MrOizo » Fri Jun 23, 2006 3:11 pm
I washed mine in petrol and just re-installed it..
no worries there. wouldnt hurt it too much would it?
Wash in pertol and then a quick air blow dry? 8)
MrOizo
Toyspeed Legend
Postby cespenar » Fri Jun 23, 2006 8:13 pm
AE82 FXGT wrote:Is it this type?
Certainly is, awesome, air gun it is then, cheers 8)
cespenar
