by KinLoud » Thu Jun 22, 2006 10:10 pm
Creaking noise? Often in Superstrut cars the creaking isn't the lower link arm. I've driven a GTZ with superstrut with totally rooted lower link arm and it didn't make a noise! It just wandered across the road!
If the lower link arm is shagged - only put in toyota genuine new!!!
Anything else wears out in about 5,000km!!!
Cost might be a bit more but you won't regret it.
To check the lower link arm:
jack up the front and take the wheels off
using both hands, grab the strut at the bottom of the spring and try to twist the suspension around.
It should not twist at all
If it does twist, look at the small lower link arm and you will see the freeplay - this means that it needs replacing.
Toyota new ones last about 100,00km
Ken
Ham
021 408 863
