Be careful.... I personally wouldnt risk it, unless someone here has had the a/f ratio checked on 5psi and can confirm its safe with stock E.C.U.crnkin wrote:just hook it up and drive it, stick with under 5psi, and yeah, do et
My bad, good point!, I just presumed its using a map sensorsergei wrote:if it has AFM it will fuel according the load (ie amount of air sucked in) so for ECU it does not matter what sort of manifold pressure. The issue would be with retarding ingnition at boost, as the N/A ecu will not do it.
Hahaha are you sure about that statement buddy? You dont know Syk or myself from a bar of soap, so how can you judge what we do and dont know?? You seem to go on alot about 4agte's and turbos yadda yadda, but do you actually own one?? show us a pic of this mysterious 4agte monster your building and then ill know you walk the walk and arent full of sh*tcrnkin wrote:Dont listen to the above people, only sergei knows what hes on about.
True-No-Turbo wrote:You seem to go on alot about 4agte's and turbos yadda yadda, but do you actually own one?? show us a pic of this mysterious 4agte monster your building and then ill know you walk the walk and arent full of sh*t
crnkin wrote:Its fine, i run it, many others run it, af's are around...
Pm me if you have any trouble, but its as easy as seting up and going.
Grotty wrote:hahahaha chris 4agte master!!!
