anone knows how to converte pop up headlights to half open
Postby Soarer T » Wed Jun 28, 2006 1:34 am
got MK 2 Supra , wanna do the pop up headlights conversion to half open.
tried adjusting them to half open. but when turn on and off the lights. they just went back.not sucessful. bugga. anyone got any ideas? cheers/
Soarer T
Re: anone knows how to converte pop up headlights to half op
Postby Toymad » Wed Jun 28, 2006 7:40 pm
Soarer T wrote:got MK 2 Supra , wanna do the pop up headlights conversion to half open.
Must be the early model Mk II. It seems the earlier models (L type) would do that whereas the later (P type) would allow you to set the height where you wanted.
You could ask Libby; she is on toyperformance.org.nz as Toy VIP. I think she may have had some success but I could be wrong.....
David
Toymad
Postby Ae92typeX » Wed Jun 28, 2006 7:58 pm
you modify the pivot arm. not too big a job really if you have some minimal workshop skills (or better than)
The adjuster thing you used is genarally for opening the lights when there is no power connected or opening if unit has failed but you still need lights to drive.
Ae92typeX
Postby evil_si » Wed Jun 28, 2006 8:28 pm
could always do it in the motor, change the limit switch
evil_si
Postby matt dunn » Wed Jun 28, 2006 9:04 pm
evil_si wrote:could always do it in the motor, change the limit switch
however you still need them to be full up when they are on.
Matt
Postby Soarer T » Wed Jun 28, 2006 10:52 pm
David
mine is 81 L type, so i think that should be swt for some modz maybe. just saw some video from japan that pople just add some switch into the main fuse box ,then they can adjust the hight of the headlights. i also had check this option, but just got no clues.rekon they probably use the different stuff. anyway, i will keep finding some sources..
Soarer T
Postby AJz » Thu Jun 29, 2006 12:23 am
a real rangi way to is to interupted the signal to the motors, put ur lights up, and as they come down you flick the switch where u want them to stop, also i know most celicas you flick the stalk back to park lights and this stops the lights halfway, Your looking for the sleepy eye effect i take it.
I had vtax :(
AJz
Postby MR2SIK » Thu Jun 29, 2006 6:11 pm
yea thats all i ever did in my mr2's, my mates old celica did the same
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
