Injector spec
Injector spec
Postby NA Drifter » Wed Jun 28, 2006 7:15 pm
By chance anyone know what the interchangeable injectors for 4age 16v (small port) motor? They are factory 235cc (2 Ohm=High Ohm?) and top feed.
I'm looking at something that's around 295cc and top feed with 2 Ohm.
Nissan CA18? or SR20 have the same injector??? or maybe 3SGE?? what are the spec etc??
thanks
Keith
Keith
NA Drifter
Postby slighty_sykotic » Wed Jun 28, 2006 8:38 pm
3sge are side feed (=20v).
2ohm is low impedance....not high.
--Sykotic
slighty_sykotic
Postby matt dunn » Wed Jun 28, 2006 9:05 pm
and the smallport are 295cc anyway.
matt
Postby Jebus » Wed Jun 28, 2006 9:07 pm
Theyre 235cc dude, 20V are 295cc but are side feed.
Jebus
Postby QikStarlie » Wed Jun 28, 2006 10:47 pm
4efte is what your after. 295 high imp. smallport are high imp. probably 13ohms or so
QikStarlie
Postby Caveman » Thu Jun 29, 2006 12:51 pm
smallport are 13 ohms. they are rated at 235cc but thats at 3bar. Most toyota injectors run at and are rated at 2.5bar.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby atmosports » Thu Jun 29, 2006 7:14 pm
Used starlet(295cc), Toyota 7mge/mgte(430cc) in various 4AGE 16V, also have used various Mitsi like VR4/Cyborg/Evo etc can't remember make models & flow. What injector you go for depnds on your application & what power your after.
atmosports
Postby NA Drifter » Fri Jun 30, 2006 12:13 am
cool, thanks alot.. so 4efte then? I'm trying to "replicate" a 16v motor with blacktop ecu running as close as std 20v blacktop. ... if u get what i mean..
Keith
NA Drifter
