Is it possible???
Is it possible???
Postby Babz » Thu Jun 29, 2006 11:51 pm
[b]Hye guys. Just wanted to know if anyone knew if it was possible to turbo a Red Top small port 4a-ge using the standard ECU. Maybe just changing the injectors for GZE ones?? And does the map read boost?? Would the map work if it was put before the turbo instead of after(wea it is originally)?? Also wats the safe psi marK??
Babz
Postby Caveman » Thu Jun 29, 2006 11:56 pm
Nope cant do any of that.
The cheapest thing you can do is turbo + 2bar map sensor + 440cc injectors (must be high impedence)
Safe boost is only around 5-8 psi.
Have a search on this forum.
Have a nice day.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Santa'sBoostinSleigh » Fri Jun 30, 2006 10:46 am
search is your friend
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
