Tensioning belts 4A-GTE...
Postby peas » Sun Jul 02, 2006 6:58 pm
Well finally got the crank pulley (175mm) off the GZE much to my relief and replaced it with a blue top one, bolted the alternator and mount (blue top again) on to where the supercharger used to sit, power steering mounted on the front (yet more blue top parts!) and looking at it have no way to tension either of the belts.
The alternator can pivot on the bottom mount but the factory blue top adjusting bracket won't bold onto the block anywhere that I can see. Is it a case of having to make a braket up to suit?
The air con has been dispatched with so the other belt (crank and p/steer) needs an additional tensioner I expect... anything that I can rob off a 4A-GE to do this that will bolt on?
'97 Caldina GT (ST215G)
peas
Postby ants_ae92 » Sun Jul 02, 2006 7:26 pm
Will either need to unbolt top bolt for power steering pump and loosen bottom one to get a belt on. Used a 4pk890 on mine (did the same thing, removed aircon ae92) as they didnt have 5pk890. then tighten it back up. Would be best to measure the length of the belt needed for exact details. At least that way you could use the power steering pump to tension the belt and not have to make up any new brackets.
Havent had to do the alternator side as mine was a 4age. But normally the alternator is what adjusts tension on the 4age.
Good luck man
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby Crucible » Sun Jul 02, 2006 8:04 pm
you need to change the small water housing on the back with an n/a one. This has two bolt holes so you can bolt up the (4age) swivel bracket for the alt. You will need to change the coolant pipe also that bolts up to it, as the gze one is also differant. You will have to make up a little bracket for the dipstick also as the mounting point differs from gze - ge water housing.
I used a ae92 p/s pump on a 4age bracket and removed the underside bolt so it can swivel. I then made up a swivel bracket mounted to the block so I could adjust the belt properly (as pic).
Crucible
Real Life Mechanic
Postby Bazda » Sun Jul 02, 2006 10:50 pm
Postby Crucible » Mon Jul 03, 2006 4:05 pm
Ahhh thats how you done yours bazda, thats a better idea mounting another bracket on the pump aswell. I had problems with the slot not lining up with the bolt hole. So made it so the slotted bracket could swivel at the front also.
Crucible
Real Life Mechanic
Postby Bazda » Mon Jul 03, 2006 6:49 pm
True-No-Turbo wrote:Ahhh thats how you done yours bazda, thats a better idea mounting another bracket on the pump aswell. I had problems with the slot not lining up with the bolt hole. So made it so the slotted bracket could swivel at the front also.
im just awesome 8)
Postby peas » Mon Jul 03, 2006 10:31 pm
Sweet as... I got a blue top water pump housing today but still not really seeing how that mounts the alternator tensioner so hope that the FX-GT is still at pick a part tomorrow :P
Simple solution to the power steering too cheers Bazda.
peas
Postby Bazda » Mon Jul 03, 2006 10:58 pm
its not the water pump housing you need.
Its the water rail that goes along the back of the head, that water rail is connected to that housing with 2 bolts that bolt to the back of the head where the alternator is. That housing has the water temp sensor for your gauge. and also on that housing this bracket bolts to it and hangs out giving you your alternator tensioner.
Postby peas » Mon Jul 03, 2006 11:41 pm
I did get that approx 1" diameter pipe bolted to the back of the water pump housing... can't see anything that helps but will have a decent look tomorrow when I have daylight and not a crappy little torch.
peas
Users browsing this forum: Google [Bot] and 29 guests
