hilux conversion
hilux conversion
Postby matt4u » Thu Jul 13, 2006 1:42 am
Im about to put a new engine in my hilux surf nd want to ask for some help.
my plan at the moment due to me not being ready to do the swap yet, I wanted to do it later in the year but thats not how its worked out.
I have come accross a 1ge that i can get for almost nothing but its only a single cam, If i was going to do this I would rather the twin cam 1geu, If I do put the single cam one in can I put the twincam head on later???? Or do the singlecam 1ge and teh twin cam 1geu have the same bell housing??
Cheers, Matt
SupraCelicaLuxSurf
http://www.offroadexpress.co.nz/images/ ... ui_001.jpg
ADMIN EDIT: oversized image removed
matt4u
Postby Alex B » Thu Jul 13, 2006 2:42 am
I think its a fella on here with a surf with a 2JZ-GE in it who rekons its the best towing wagon ever. Lexus V8 is the other common mod.
Postby KinLoud » Thu Jul 13, 2006 9:39 am
Swapping heads - anything can be made to fit but just swap the whole engine over.
The G motors will have the same bellhousing and the G engine bellhousing will bolt onto any hilux/surf manual gearbox.
Do a search on the internet for people who have transplanted other motors into their hilux/surf.
Good luck.
Ken
Ham
021 408 863
Postby matt4u » Thu Jul 13, 2006 4:47 pm
Ye I have a bit of info on engine swats but most ppl dont bother with the 1GE. Its not really what I want and wont be for longterm anyway.
SupraCelicaLuxSurf
matt4u
Postby matt4u » Thu Jul 13, 2006 4:48 pm
pyro_sniper2002 wrote:I think its a fella on here with a surf with a 2JZ-GE in it who rekons its the best towing wagon ever. Lexus V8 is the other common mod.
Like this
SupraCelicaLuxSurf
matt4u
Postby strx7 » Thu Jul 13, 2006 8:00 pm
No, the rad support doesn't need to be cut.
Its more like this......
http://strx7.250x.com/index.htm
I'm in the process of sussing out either lower compression pistons or 3mm geasket and ARP headstuds so i can bolt a dirty great turbo to the side of it.
Shane
Postby matt4u » Thu Jul 13, 2006 8:33 pm
I see you had to make a new sump cause you have ifs. The rad support is cut to make it easier.
Here is a write up on that swap Here
SupraCelicaLuxSurf
matt4u
Postby strx7 » Thu Jul 13, 2006 10:58 pm
I even managed to thread my engine and box thru the engine bay and into the tunnel all in one piece
Postby matt4u » Thu Jul 13, 2006 11:26 pm
of course its all possiable. Its also easier to work on with it out, that truck is quite a bit higher than yours, lol. but good effort.
SupraCelicaLuxSurf
matt4u
Postby Jason T » Thu Jul 13, 2006 11:37 pm
Same bell thru engine family
But there are better engines out there than a sohc 1G you would be better of with a 21R than that boat anchor
Theres a 5MG on Tardme with loom and ecu you want to go up in power rating not backwards
8)
Fixing Toyota's since '87
Jason T
Postby matt4u » Fri Jul 14, 2006 12:00 am
Yea there was one on there ut the guy wouldn't answer my questions,
Im only thinking about a 1g cause I have been offered a whole car for free, its not going to be a perminant thing just to get me through till next year. save up to do a 2jz swap
SupraCelicaLuxSurf
matt4u
Postby matt4u » Fri Jul 14, 2006 12:10 am
Or mabe a 1g gte
SupraCelicaLuxSurf
matt4u
Postby Jason T » Fri Jul 14, 2006 12:15 am
Hey if it comes with the rest of the car attached then makes a easy conversion 8)
Jason T
Postby matt4u » Fri Jul 14, 2006 12:19 am
thats the reason im thinking the 1g just for the moment, I'll have everything and can get it up and running again, just have to keep her bouncing off limiter the whole time, or mabe mount my turbo off my 2LT onto it, LOL
SupraCelicaLuxSurf
matt4u
Postby matt4u » Fri Jul 14, 2006 11:15 pm
Well the 1g is out of the question, I just brought a 5mgeu!!!!!
SupraCelicaLuxSurf
matt4u
Postby KE20 » Sat Jul 15, 2006 9:43 am
i put a 2jzge into my 1988 hilux, original sump(mid sump) and all, every thing clears, just like its made for it.
and got it dynoed other day and is 130kw@wheels and 612NM torque(torque performance dyno), and is great for towing. 5th gear everywhere.
Garage Dori
KE20
Postby matt4u » Sat Jul 15, 2006 11:36 am
yea theey are a far better fit than a 5m
SupraCelicaLuxSurf
matt4u
