gt-t clutch urgent
gt-t clutch urgent
Postby trdfxgt » Mon Jul 17, 2006 5:07 pm
hey i have a friend with a manual gt-t it has a good clutch fitted as there is no slip as hard as i can try to make it slip :-) ha ha but it grips way to early which make it very difficult to drive has any had this before and had any solutions ?????
when i think of something witty ill put it here
trdfxgt
Postby Truenotch » Mon Jul 17, 2006 6:58 pm
Try having a look in the manual to see how to adjust the play in the clutch to make it grab at a different point, it might need a bleed, thats easy.
Otherwise just learn to drive it how it is.
Truenotch
Postby mikeygtt » Mon Jul 17, 2006 11:08 pm
Truenotch wrote:Otherwise just learn to drive it how it is.
Mine is the same, grips real early but once you get used to it, its really good. Will help there clucth control skillz 8)
uhmmm yup
mikeygtt
Postby u4dina » Mon Jul 17, 2006 11:43 pm
Mine's exactly the same after i replaced the clutch...
But i find it good after getting used to it....
1998 5spd Gt-T Caldina loving it...........
u4dina
