Link Lem trig 1,2 4age
Postby AceSniper » Sun Jul 23, 2006 11:40 am
Putting a lem in and im down to putting the triger wires in but the "slip" thats ment to be in the back of the manual is missing can anyone say how these are ment to be wired up for a 20v?
thanks
AceSniper
Postby QikStarlie » Sun Jul 23, 2006 3:13 pm
QikStarlie
Postby repowered » Sun Jul 23, 2006 3:44 pm
what does that do? just out of curiosity
Rollin!
repowered
Postby AceSniper » Sun Jul 23, 2006 6:29 pm
cool thankyou
AceSniper
Postby matt dunn » Sun Jul 23, 2006 9:38 pm
There is more than one way of wiring them depending on the age of the link. If it's V4 or newer, or has had the sub board changed to suit a 20V in the last few years that will be correct.
My old V3 that i had was wired very different to tha in the triggers and needed the dist modified as all the loder models did.
Matt
Postby AceSniper » Sun Jul 23, 2006 9:43 pm
ah sweet thanks, its a v5 and has 20v on the side so should be right, doit during the week if I get time :)
AceSniper
Postby DexGT » Sun Jul 23, 2006 11:38 pm
It depends on the trigger type in the dizzy , early 4A-GE had a single tooth , the later ones got the 24 tooth type , so the link needs the right sub board , and the right wireing.
The above diagram also works for 4E-FTE's ..... I think you sent me the same pic Qikstarlie 8)
DexGT
Postby matt dunn » Sun Jul 23, 2006 11:47 pm
All the 20V's have the same dist,
One 24Tooth and two single tooth sensors,
Matt
