Reverse Light not working?! AE101 help?
Postby DB4G63 » Sat Jul 29, 2006 9:42 am
Hi All
Had a stereo installed last week by a friend, however now Ive noticed my reverse lights are not working....(AE101 GTZ)
Im not sure if its related to the stereo install or not, since I was there, and the wires appeared to be all the right ones.
It seems kinda weird that BOTH reverse lights arent working at the same time.
Ive pulled the lights off and checked the bulbs which appear to be fine.
Ive checked the fuses both inside the footwell AND in the engine bay.
What should I do now?
:D Thank you!!
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby trueno_20v » Sat Jul 29, 2006 10:15 am
checked the plug that goes onto the sensor on the gbox?
ADMIN EDIT: signature too large
trueno_20v
Postby bluemaumau » Sat Jul 29, 2006 12:52 pm
trueno_20v wrote:checked the plug that goes onto the sensor on the gbox?
my bet also
Postby DB4G63 » Sat Jul 29, 2006 1:26 pm
Im guessing this is on the gearbox itself? or is this under the gear selector?
DB4G63
Postby trueno_20v » Sat Jul 29, 2006 1:40 pm
on the gearbox, at the back, right by the rear mount, its a black plug, hard to see :wink:
trueno_20v
Postby AceSniper » Sat Jul 29, 2006 6:04 pm
trueno_20v wrote:on the gearbox, at the back, right by the rear mount, its a black plug, hard to see :wink:
thats the speedo drive off the diff
its a grey plug ontop of the gearbox easy to see then u look, mite be abit diffrent on a gtz E box tho
AceSniper
Postby DB4G63 » Tue Aug 01, 2006 12:49 am
Man its hard to see what Im looking at...
Ill post some small pics up.
I see a small grey plug on the very top, but it appears plugged in.
Should I try changing the bulbs anyway?
A friend of mine whos experienced with car stereos installed a stereo two weeks ago...is it possible he buggered some wire? Do the rear light wires run up the centre console at all?
I had a rear bulb blow tonite ( dash light came on...so I have to change it anyway)
DB4G63
