charcoal canister
charcoal canister
Postby Santa'sBoostinSleigh » Tue Aug 01, 2006 6:36 pm
ok, well nearly done sorting issues out....
do i need to run the charcoal canister? (blacktop 20v)
if not, what do i do with the in and out lines??
(will do pix later this evening)
the engine bay is fairly full, so if i dont need it good!!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby no_8wire » Tue Aug 01, 2006 6:41 pm
yes you need it...unless you want your car to go up in flames...
no_8wire
Postby Dragger_Dan » Tue Aug 01, 2006 9:48 pm
What exactally does the charcoal can do? Is it for recycling the fumes from the tank or something?
Dragger_Dan
Postby Rick » Tue Aug 01, 2006 9:58 pm
Dragger_Dan wrote:What exactally does the charcoal can do? Is it for recycling the fumes from the tank or something?
Pretty much, the charcoal canister is used to trap the fuel vapors. The fuel vapors stick onto the charcoal, until the engine is started, and engine vacuum can be used to draw the vapors into the engine, so that they can be burned
Postby Ae92typeX » Tue Aug 01, 2006 10:05 pm
Definition: A storage device in the evaporative emissions control system. It is a small cylindrical or rectangular container that contains activated charcoal particles. The charcoal traps gasoline vapors from the fuel tank (and carburetor on older vehicles). Later, the vapors are purged and drawn into the engine when the vehicle is being driven. See EVAP System. (autorepair.about.com)
edit. lol, stoopid msm delays my replies...
Ae92typeX
Postby 4000GT » Tue Aug 01, 2006 11:07 pm
no_8wire wrote:yes you need it...unless you want your car to go up in flames...
Lies.
You can vent it straight into ATM. I personally put a fuel filter on the end of the so dirft wont go up the line.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby gasman » Tue Aug 01, 2006 11:10 pm
when i put my engine in i just plugged it up to what the old vent from the petrol tank went to which was a small round thing. car was a carby btw now 20v. got certs and wofs no problems
"What can possibly go wrong?"
gasman
Postby Paulio » Wed Jun 25, 2008 9:58 am
what happens when the turbo is pushing 1 bar through the vacuum hose into the charcoal canister?
is the charcoal canister really needed?
Paulio
Postby RunningRich » Wed Jun 25, 2008 11:02 am
not_paul_from_waiheke wrote:what happens when the turbo is pushing 1 bar through the vacuum hose into the charcoal canister?
You mean pushing 1 bar aginst the one way check valve between the manifold and canister :wink:
It isn't needed. Mine vents straight to atmosphere. My intention was saving (a little) weight and also reducing the complexity in the engine bay.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Paulio » Wed Jun 25, 2008 11:14 am
RunningRich wrote:You mean pushing 1 bar aginst the one way check valve between the manifold and canister :wink:
oh there is a 1 way valve in those throttle body nipples?? well thats handy!
RunningRich wrote:It isn't needed. Mine vents straight to atmosphere. My intention was saving (a little) weight and also reducing the complexity in the engine bay.
Thats what I wanted to hear and thats my intention too.
Paulio
Postby rollaholic » Wed Jun 25, 2008 7:20 pm
the standard ecu will expect to have those hydrocarbons avaliable at certain operating conditions though, so you may find it running leaner than is ideal sometimes.
evap normally only functions at cruise speeds, but increased combustion temp from lean mixture could lead to knocking in high compression blacktop, leading to retarded timing and less power!
but probably not.
for the above poster, one way valve is part of evap canister.
edit - for what its worth, you wont see any performance gains from losing it, and you will probably get better mileage with it installed. think of it as getting your moneys worth - those vapors are your $2.25 per litre gasoline evaporating, if you vent it to atmosphere its like chucking money out the window!
and burning the vapors is a much more considerate way of disposing of them :P
Postby Paulio » Wed Jun 25, 2008 8:01 pm
Interesting yes.
Unfortunately I cant consider mileage as this isnt an economy car.
Ive installed a link now so wouldnt think it would give a dog about how to get the most out of $2.25. And its damn ugly and in the way of all my pretty chrome & silver shit.
Edit: i like burning though
Paulio
Postby rollaholic » Wed Jun 25, 2008 9:12 pm
you'll note i said the stock ecu
and i was mainly responding to OP anyway :P
Postby method » Sat Jun 28, 2008 4:31 pm
Just ditch the canister because its big and ugly and plum the evap line straight into manifold. Keeping the 1-way valve if it has one of course!
Have done this and never had a problem. Also dont get a shity smell from all the fuel vapors in your cabin.
PICS UPDATED DAILY
method
Postby rollaholic » Sat Jun 28, 2008 6:12 pm
the valve is part of the canister in most cases.
if all you are concerned about is performance you are better off venting the tank to atmosphere, as fuel vapour is more likely to detonate than burn.
Postby bluemaumau » Sun Jun 29, 2008 2:29 pm
what do people do witht he line that goes to your fuel tank, if thats where it goes
Postby Paulio » Mon Jun 30, 2008 11:50 am
Ive taken it all out now and it looks so much better in the bin!
Paulio
Postby bluemaumau » Mon Jun 30, 2008 5:42 pm
yea but isnt there a hard line on the firewall next to the return line?
Postby Paulio » Mon Jun 30, 2008 6:18 pm
Yeah, dont know what to do with that??
Paulio
