Does anyone know why the engine would do this?
car in question here is a ST165 GT-Four. i thought it was to to with a vac leak which i have tracked and sorted.
only does this when coming to a stop rolling out of gear :/
Akane wrote:What do you mean by "bouncing"? as if power is being applied on and off?
Now the injectors should shut off when you coast, wondering if your TPS is dead, making injectors go on and off :/
RedMist wrote:I gather you are talking about hunting. I would suspect its still a vacuum leak. However its only leaking when you are pulling high vacuum. As such its going to be a PITA to find.
Users browsing this forum: Bing [Bot] and 8 guests
