exhaust wrap
exhaust wrap
Postby phat_levin » Thu Aug 03, 2006 9:34 pm
just a quicky, if i was to take my extractors off to wrap them, are there any gaskets in there? and if there are can i just use the old gaskets when i put it all back together or would i need new ones.... :oops: :? :?:
phat_levin
Postby Crampy » Thu Aug 03, 2006 10:34 pm
Why take them off? I just heat wrapped mine in situ...
Crampy
Postby slighty_sykotic » Thu Aug 03, 2006 11:16 pm
if you do take them off, yeah you will need a new manifold gasket. $25ish from toyota, or a acl/permaseal/other aftermarket one for less. Or revhead..
--Sykotic
slighty_sykotic
Postby AceSniper » Thu Aug 03, 2006 11:47 pm
the steel mani gasket should be able to be re-used, but there is two rings on the 2ndrys that need to be replaced
AceSniper
Postby 4000GT » Fri Aug 04, 2006 12:07 am
AceSniper wrote:the steel mani gasket should be able to be re-used, but there is two rings on the 2ndrys that eed to be replaced
Yup
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby cosi » Tue Aug 08, 2006 9:26 pm
AceSniper wrote:the steel mani gasket should be able to be re-used, but there is two rings on the 2ndrys that need to be replaced
... they cost $8
cosi
Users browsing this forum: Bing [Bot] and 4 guests
